Has anyone ever experienced a bad oil cooler?
Old Sep 29, 2019 | 04:22 PM
cw383's Avatar
I have an LDK motor, just trying to trace an internal coolant leak. Coolant in oil, but not oil in coolant. Compression is good, new head gasket. When I pressurized it with a coolant pressure tester drips coolant out the pan. Before I drop the pan, I'm wondering if anyone here ever had an oil cooler fail and put coolant in the oil. Otherwise, its a cracked coolant passage. Water pump isnt leaking either.
Old Sep 29, 2019 | 04:25 PM
I think a few LSJ oil coolers have failed, dnt know about LNF but its possible, remove the coolant lines to bypass the cooler and see if it still leaks the same.
Old Oct 1, 2019 | 03:41 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I, as well, have heard of leaking LSJ systems, but not LNF. I do have a spare LNF cooler that I will never use, if you're interested.
SilverSpeed
Jun 22, 2019 03:42 AM
user 72239
Feb 13, 2019 02:08 PM
BoostedDreams
Apr 21, 2016 06:41 PM
joshcsepegi
Dec 12, 2013 10:26 AM
Pauliejp
Feb 2, 2013 12:26 AM
