oil in coolant no coolant in oil.
Old Dec 11, 2013 | 06:56 PM
joshcsepegi's Avatar
So like the subject says . I have oil in coolant however no coolant in my oil.
I thought head gasket. however a more knowledgeable mechanic then me says oil cooler. could this be?
next anyone have a oil cooler for sale?
Old Dec 11, 2013 | 07:15 PM
mongorat427's Avatar
I HAVE A FEW. iLL BE HOME sUNDAY
Old Dec 11, 2013 | 08:43 PM
BLKLS's Avatar
Sounds like an oil cooler... I have an old Audi at work with the same issue.
Old Dec 11, 2013 | 08:58 PM
ItalianJoe1's Avatar
Definitely the oil cooler, I've replaced them before on an LSJ for that exact issue. Cooling system was FULL of oil, super nasty and hard to flush it all out. Oil was clean as a whistle.
That's due to the high oil pressure, it leaks slowly only from the high pressure, into the coolant. Apparently there's not enough cooling system pressure to leak back the other way even after the motor is shut down.
Old Dec 12, 2013 | 07:41 AM
How hard its it to change? Like 4 bolts?
Old Dec 12, 2013 | 10:26 AM
It's not bad at all, I think there's only about 3 bolts holding it to the block right by the oil filter. You may have to move some stuff for access but it's pretty easy to reach. Will be messy when you remove it, oil and coolant everywhere .And you should flush the cooling system to remove the oil, I washed everything out with degreaser and a hose and kept flushing until it was coming out clear.
brandon04
Oct 21, 2015 07:04 AM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
