Has anyone had a cam position sensor go bad?
Old Jun 25, 2010 | 10:34 AM
XXL's Avatar
XXL
My computer is spewing forth CEL's that the exhaust cam position sensor is bad (thanks T2). I asked around in some local circles and nobody had experienced this... and then when ordering the part from CED (thanks Tom), he indicated that he hasn't sold any of them... which means nobody's asking him for them-- 'cept me. Did mine just decided to die at 25k miles because I'm special? Or are others seeing these sensors fail? Or???
Old Jun 25, 2010 | 10:41 AM
Staged07SS's Avatar
Administrator
Administrator
Mine failed 2 years ago. I think I had 15,000 miles on it at the time.
It threw a code, and ended up causing starting issues.
I had it replaced at the dealership under warrenty.
Old Jun 25, 2010 | 11:47 AM
BYT*SS*TURBO's Avatar
I had mine throw a code for it once, I cleared it and it never came back.
Old Jun 25, 2010 | 12:12 PM
supermantxz24's Avatar
there has been alot of people that had to get their cam position sensor replaced but it seems like i havnt seen people post up lately about it it was more when the tc's first came out.
Old Jul 5, 2010 | 09:23 AM
XXL's Avatar
XXL
Sensor from Tom at CED arrived. PN# 12577245. I'm going to install today.
Old Jul 5, 2010 | 04:46 PM
Terminator2's Avatar
My intake cam sensor was leaking oil at the O-ring a year or so ago. Black RTV took care of that. No issues other than the minor oil leak.
Old Jul 5, 2010 | 07:01 PM
XXL's Avatar
XXL
  • Installation time-- 10 minutes (including putting away tools and washing hands)
  • Time spent looking for that stupid gray plastic connector lock-- 30+ minutes (which I never found)
Has anyone got a spare one they'd like to stick in an envelope and send my way?
Jeebus! Does it ever end? AFTER sensor replacement, I'm still getting the following...
[ECM] P2090 - Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage Bank 1 (Pending) (Immature)
[ECM] P0013 - Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Bank 1 (Pending) (Old) (Current) (Immature)
[ECM] P2088 - Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage Bank 1 (Pending) (Immature)
[ECM] P0010 - A Camshaft Position Actuator Circuit (Bank 1) (Pending) (Old) (Current) (Immature)
[ECM] P0245 - Turbocharger Wastegate Solenoid 1 Low Voltage (Pending) (Immature)
[ECM] P0243 - Turbocharger Wastegate Solenoid 1 (Pending) (Old) (Current) (Immature)
[ECM] P0034 - Turbo/Super Charger Bypass Valve Control Circuit Low (Pending) (Immature)
[ECM] P0033 - Turbo/Super Charger Bypass Valve Control Circuit (Pending) (Old) (Current) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Incomplete
Heated Catalyst: n/a
Evaporative System: Incomplete
Secondary Air System: n/a
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Incomplete
EGR System: n/a
I collected the above after warm-up. I've checked connection MANY times. It's connected. Anyone?
Old Jul 5, 2010 | 07:27 PM
army_greywolf's Avatar
Erase it, take it for a drive, repeat check, see what comes back up.
Old Jul 5, 2010 | 10:17 PM
XXL's Avatar
XXL
Erase the DTC's? Did that 20 times during the 45 minute drive. They instantly returned every time.
Old Jul 6, 2010 | 06:59 AM
reddevil's Avatar
you hyave a poor connection causing low voltage.. i think you need a tech to trouble shoot your problem and stop wasting money on parts you do not need.
Old Jul 6, 2010 | 09:08 AM
Must be a bad connection if it is not the sensor itself.
Old Jul 6, 2010 | 12:59 PM
XXL's Avatar
XXL
And therein lies the real problem, and the basis of my other post here. I agree. I need someone to take the car and make it work. Every dealer in my area has proved its gross incompetence with this car (frankly, with service in general)... unless someone has a recommendation for a dealer in the SF (east) Bay area where they've had actual quality service done, and can offer up a service tech or manager's name I should be talking to...
Kill me now.
Old Aug 24, 2011 | 04:43 PM
victoryredturbalt's Avatar
u have a car starter installed? ^
Old Oct 3, 2011 | 12:39 PM
mongorat427's Avatar
Mine just threw a couple codes 341 300 303 304 and I was racing in the rain at Beaver Run . Not sure if some water got in it somehow or what but I cleared the codes and will wait for this *&%^&^%$@#%$^&*&^%$##%&__()*&%@#%$&^*( **** FN weather drys out before I try to dry it out. Car was running great on the NTO1s even in the rain
Old Oct 3, 2011 | 12:43 PM
outtamymind's Avatar
OP how long does it take for you car to crank over, do you notice any dimming of your lights. how old is your battery?
Old Oct 3, 2011 | 12:50 PM
cranemaster's Avatar
I think mine went, which blew up my IC, which made my car go blow out black smoke and run rich as ************. Got it fixed under warranty..
something like that lol
Old Oct 4, 2011 | 11:36 AM
Just bought 2 $36 bucks ea
Old Oct 4, 2011 | 06:20 PM
Iam Broke's Avatar
Lost an intake cam actuator at ~50k, but no position sensors.
Old Oct 4, 2011 | 06:29 PM
bbrewbaker's Avatar
My exhaust one die last week at 25k. Had it replaced under warranty.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 13, 2015 09:32 PM
cw383
Sep 30, 2015 12:41 AM
jmelton327
Sep 26, 2015 10:04 PM
