Headgasket
Headgasket
Just a quick question to everyone who has made a high horsepower pull, want to kno if your running the stock headgasket or aftermarket. manily the guys who have boosted over 28psi. thanx
im an lsj but i boost 29-30psi...arp headstuds and a cosmetic headgasket jus make sure u retorque the headstuds after the first heat cycle and a small drive and check them once in awhile to make sure there still good
u boost that on stock turbo?? if u are, ur ring lands will be gone shortly. this has been a big discussion on here when people first started boosting past 24 psi stock turbo. stock turbo is efficient to about 24ish psi, then it just produces a buttload of heat. if i was u, if u are on stock turbo, dial it down asap
as per my other threads, motor being rebuilt bottom up, zzp trans, full turbo swap PTE5857, worrying bout blowing the stock head gasket when i get tuned i just brought ARP studs from a fellow css mbr, looking to see wut the turbo can really do im lookin for 540whp when its all said and done, but would like to see a pull on race fuel to see what my build is capable of.
RednBlack
Nov 19, 2009 10:52 PM
2K5SS/SC?
Oct 1, 2007 03:57 PM
