Help!! Losing Coolant
Old Sep 17, 2011 | 11:23 AM
hawkssoccer11's Avatar
Yesterday my low coolant light came on. i filled it back up and then about 3 hours later it came on again. so i pulled over popped the hood and it was low again. i crawled underneath the car and nothing was leaking underneath. Right now i have the car on the lift and theres still no leakes. wheres the coolant going? Is it the head gasket?? any help would be nice. thanks.
Old Sep 17, 2011 | 11:26 AM
nhanson's Avatar
what could of happened is the radiator got low and since you filled the overflow it took all your coolant.
try another fill and see if it eats it up. you could also try popping the large coolant hose on top and see if theres any
actually try popping the hose on a cold engine first and if low then fill through the hose. THEN fill your overflow
Old Sep 17, 2011 | 11:42 AM
oh ok i gotcha. when i popped the hood the second time the cap seemed a little loose but it was still tight. so the pressure could have pushed some out too.
Old Sep 17, 2011 | 12:34 PM
shredout's Avatar
head gasket or water pump. i just recently had to replace both.
Old Sep 17, 2011 | 12:42 PM
tomj77's Avatar
porus block is usually the issue with that problem around here, i had it and a few others did to
Old Sep 17, 2011 | 04:40 PM
094doorSS/TC's Avatar
You have a porus block more then likely, it's a 2009 issues they had with some blocks, put it back to stock and go in to the dealer for the new motor.
Old Sep 17, 2011 | 05:03 PM
mkulrey13's Avatar
You have the porous block issue. Go back to stock and prepare to fight. Took me 100+ days of arguing to finally get my motor replaced under warranty. Dealer didnt even know the porous block issue exsisted. Check your oil its most likely milky.
Old Sep 20, 2011 | 03:48 PM
just to let you guys know. took it to the shop monday and found out today that it was a head gasket so they ordered the part and should have the balt back by the end of the week i told them to check the block and the head.
Old Sep 20, 2011 | 04:50 PM
Frogstofall's Avatar
Head gasket eh? Did you have large amounts of white smoke on startup and initial driving?
Old Sep 25, 2011 | 08:46 PM
sorry that i havent been on all weekend. but found out more bad news. on friday after they kept looking thursday. its a cracked block so i got a new motor on the as of friday.
Old Sep 25, 2011 | 08:55 PM
dayhoff35's Avatar
yepp i had the same problem, glad yours is getting taken care of fast though!
Old Sep 25, 2011 | 09:00 PM
yeah man me too. they didnt give any me **** yet either. (knock on wood lol). what exactly is porus block btw?
Old Sep 25, 2011 | 09:01 PM
dayhoff35's Avatar
from what i understand its small pores in the engine block that leak coolant into the oil
Old Sep 25, 2011 | 09:04 PM
oh ok gotcha thanks man
Old Sep 25, 2011 | 09:17 PM
vahdyx's Avatar
I have 17000 miles on my 2009, what are the odds of me having this issue?
Old Sep 25, 2011 | 09:31 PM
dayhoff35's Avatar
should have showed igns already mine happened at like 7k
Old Sep 25, 2011 | 10:10 PM
vahdyx's Avatar
I see, I got a low coolant waring at like 7000 miles, but then I threw coolant in it and it hasn't been a problem since.
Old Sep 25, 2011 | 10:11 PM
Matt M's Avatar
They like to call them porous blocks, but they are cracking internally, between the water jacket and the oil drainback passages. It is due to the aluminum being too thin through certain areas, but it can show up after you start making more power or loading the engine harder.
Old Sep 25, 2011 | 10:17 PM
Wangspeed's Avatar
Thanks Matt. I hate the term "porous block" solid metal doesn't suddenly start passing fluid without a reason.
Old Sep 25, 2011 | 10:22 PM
vahdyx's Avatar
So if this "cracking" were to happen to me, does ZZPs block address this issue or can it succumb to it as well?
Granted I'd be cheaper to go get a warranty fix, but if I have to battle with them, I'll just buy one from ZZP and pump up the power lol.
Old Sep 26, 2011 | 06:39 AM
SSlobalt's Avatar
I think the word "porous" just started getting thrown around because of the styrofoam casting marks.
Old Sep 26, 2011 | 11:09 AM
Wangspeed's Avatar
This thread should become a sticky, for Matt's post if nothing else. Cracked blocks should be the new term.
Old May 9, 2014 | 08:40 PM
jeffcollins05's Avatar
Also Missing Coolant!
Hey, I'm having the same issue here. Here's the thing, there's no leak, and no milky liquid in my oil. My dad is a mechanic but I haven't had him look at it yet. But basically every month and a half I get low on coolant, but there's no smoke, no puddles, nothing! Any help would be appreciated!
Old May 9, 2014 | 10:12 PM
cmiller8006's Avatar
Without reading, check your oil. I am going to go with 99% its the block
Old May 10, 2014 | 06:03 PM
SSlobalt's Avatar
Do you have an '09? I think they only warranty for 5 years, so you better get that thing diagnosed ASAP. It looks like only the very late '08 and early '09 cars have the cracked block issue.
