Help with Oil Temp Gauge Install
Well, kinda. It's better than nothing, but the oil temps run pretty hot. On a summer day, it can read 280 on the bogus calculated oil temp from the ECU. It's a good thing to monitor with a real temp sender. Oil pressure is better monitored with a high pressure switch connected to a dummy light. A gauge is too slow (unless data logged). A bright annoying light would work much better, especially for quick drops in oil pressure, like oil starvation under high-g cornering.
It's actually the far right of the three. The left one is the oil feed for the turbo. I can try and get a better picture tomorrow with the engine out of the car.
There isn't much room, so I remote mounted my sending unit, but this is where the plug is that I was talking about.
z28addiction
Sep 28, 2015 12:03 AM
