Help please! Terrible wobble.. Then went away..
Does it go away every time u push in the clutch.....even at different speeds?
I would be inclined to look at the drive-line if that's the case. Maybe your cv joints are worn ?? Does it make any noise in the drive line when shifting....like an audible clank or anything? You can also check and see if the axle nuts are tight ... they should be 155 ftlbs IIRC .
Axels will wobble under load if a bearing is broken in the boot. And when you let off the gas it could and will more than likely go away. On my redline I have broken 4 axels this way. But doesn't sound like your issue, as the shaking was violent, and scary as ****
Noise/vibration would change based on rpm not wheel speed.
Anything wheel or tire based should not go away when clutch depressed.
I think the most likely cause is something between the two like an axle but don't discount broken/bent suspension or steering components.
Good shot. Ha so like i said. U mentioning th clutch being pressed made it go away wasnt true. But good job and remember it could be worse haha
Okay so control arm bushing is in.. Still wobbling pretty bad.. Hasn't changed much. Next thing is tires. Gettin new tires tomorrow...
Anyone here know the exact symptoms of a cracked flywheel?.. This is driving me crazy and I really hope it isn't trans/clutch/flywheel related
Stop throwin random **** at it.
It can't be flywheel if it is speed based like you say and not rpm based. Read my earlier post and trouble shoot it or bring it to someone who knows how.
Isn't that what trouble shooting is? An it's not speed nor rpm based.. I feel it depends on the load. It's extremely hard to explain
Is it only during acceleration? My front right wheel shakes on acceleration. I got new tires, balanced, checked all the points underneath. Not alignment, got a new clutch thought it would be fixed after they take it apart and put it back.. nope. I'm leaning towards the last option, maybe a bent axle or the open diff in the transmission died. That's me though.
You led us all astray with the "clutch" comment, but it's all good.
