Hesitation when at WOT????
Old Jul 26, 2009 | 01:59 PM
1SLOLT1's Avatar
I have a 09 Cobalt SS when i go full throtle from 2nd gear or third gear and as soon as full boost kicks in as im accelerating the car feels like it gains and looses power almost like a jerking feeling??
Has anyone had this problem? is this normal? Car only has 900 miles on it
Old Jul 26, 2009 | 03:15 PM
DoMiStIc_RuSh_06's Avatar
mine does this sometimes as well...kinda wierd
Old Jul 26, 2009 | 03:31 PM
FRQ FLYR's Avatar
I'd guess it's the learn-down limiting overall torque; not sure but I believe this happens more often when you're low mileage. I was pretty easy on mine for the 1st couple thousand-when I did get on it never experienced any "jerkyness" though?
Old Jul 26, 2009 | 04:15 PM
Red_SS/TC's Avatar
I get this too sometimes in third gear and i only have 900 miles too.
Old Jul 26, 2009 | 04:27 PM
1SLOLT1's Avatar
ok makes me feel better now!
so it goes away with mileage?
Or would a tune help with this?
yeah mine does it in both, but not first gear.
If i go from a dead stop and run the car it doesnt do it but from a roll it does???
Old Jul 26, 2009 | 04:28 PM
platinumrims's Avatar
um... my 0-60s aren't anywhere close to 6 seconds lol what's yalls? I'm not peeling my tires though either
Old Jul 26, 2009 | 04:33 PM
1SLOLT1's Avatar
mine will hook well and when full boost kicks in at 1st gear the tires break loose and then i chirp in 2nd gear in my Balt.
Red_SS/TC's Avatar
Yeah exactly but mine hasnt done it lately but I have felt it before and then you floor it again and it doesnt do it.
Old Jul 26, 2009 | 11:46 PM
redstarpa69's Avatar
do any of you guys have bolt-ons or its stock? If you have bolt-on's take them off - your motor needs to "break-in" - rule of thumb - at the first 1000 miles change your factory oil/filter, this removes any residue from the factory {flakes/grease/grime/dust}, then after other 1000 miles change it again "removes more residue", after the 3rd time your oil should be "clean from residue" when its been changed, then you can install your toys and get a tune.. when you do this, your motor will be very happy!!
after following these instructions - i never had any motor problems with any of my cars in 20 years..
what causing this "jerking or lag", is the motor breaking in.. it's the ecm "learning".. after 4000/5000 miles it goes away.. normal..
Last edited by redstarpa69; Jul 26, 2009 at 11:47 PM. Reason: Automerged Doublepost
Old Jul 31, 2009 | 05:37 PM
lnfski09's Avatar
Is it pulling timing? Mine does it when I roll in to it in second gear from 3500 rpm. RPD shows 6 degrees kr then backs off to 2 degrees. I have only done this twice due to low miles (im little over 200 miles, but have never stabbed it since I got it, lol). Curiosity kills some times Im hoping that the KR issue will go away after a few more miles get put on.
Old Jul 31, 2009 | 06:45 PM
Iam Broke's Avatar
The stock timing curves will have KR in the midrange RPM area under load even on 93 octane.
Old Jul 31, 2009 | 09:32 PM
orbalt08's Avatar
I have about 15000 and still experience exactly what the op describes. I have gauges to monitor everything and the culprit is knock retard. Only way around it is to tune it, or not go wot, but then again I still get it when I feather into the power. Hope this helps
Old Jul 31, 2009 | 10:16 PM
lnfski09's Avatar
I work for the company, and im floored that they let a vehicle go in to production with these symptoms. When we test the engines at work, we mask alot of this stuff out due to wanting these things to granade (well not grenade, but atleast find issues with them). They are frickin awsome power plants thats for sure! Thats why I went out and bought one. And im glad I did! This is my second post but I have done a bunch of reading up on the site and this site has been very helpful with "Real world" issues.
Once again, LNF FTW!
Old Jul 31, 2009 | 10:28 PM
Jbernal4368's Avatar
mine does that if the tires spin, and its the ESC trying to get traction again
Old Aug 1, 2009 | 12:45 PM
lnfski09's Avatar
Hmmm interesting... even with traction control off, it seems like i still cant get the tires to break loose... would esc have anything to possiably do with that? how do u turn esc off as opposed to tcs? could esc cause timing to be pulled?
Old Aug 1, 2009 | 07:47 PM
orbalt08's Avatar
i believe you just hold down the traction button until it says esc off
Old Aug 1, 2009 | 11:45 PM
lnfski09's Avatar
You hit the nail on the head with that one! I shut it off and rolled in to it in second at about 3k, and NO KR (At this point, it would pull about 6 degrees)! Man this thing feels like a totally different car!
Old Aug 2, 2009 | 12:54 AM
yay... i got something right!
Turbo Johnny
Feb 21, 2019 09:41 AM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
007Buff
Jun 11, 2017 03:04 PM
717ssbalt
Oct 2, 2015 04:01 PM
007Buff
Sep 22, 2015 09:48 AM
