High Pressure Fuel Pump Mod
Old Mar 30, 2011 | 01:21 PM
mongorat427's Avatar
Well for good or bad I decided to Mod one of my spare fuel pumps. Not sure how Im going to test it as I dont have HPT. Using a low speed drill press and homemade fixture I opened the inlet and outlet to 3/16. The stock size being 11/64 and a brass restrictor in the other side which was very small. It was so small I couldnt measure it. Weather it was there for a purpose we will fine out. If the fuel pressure goes up to 4000 then I will know if I f--ked up a good pump
Before and after
Old Mar 30, 2011 | 01:26 PM
Pyros777's Avatar
Wouldn't a larger opening give you lower pressure, but more volume, ultimately canceling itself out? Just thinking out loud here. Its always fun to try stuff with spare parts, lol.
Old Mar 30, 2011 | 01:28 PM
Terminator2's Avatar
Normally on a pump when you enlarge the inlet and outlet the resulting pressure (resistance to flow) and fluid velocity (how quickly the fuel is delivered to the rail and injectors) will go down if flow rate (GPM) is kept the same. If the pump is being restricted by the size of the inlet and outlet this is a good mod if not a low rail pressure code will likely result as well as slower fuel delivery. Must test to find out.
Old Mar 30, 2011 | 01:33 PM
drewbroo's Avatar
Subbed
You might be right and now we need to test it. I need to get a measurement of the ID of the High pressure fuel rail
Old Mar 30, 2011 | 01:39 PM
jb09ss's Avatar
You will only have reduced the internal loss of charge of the pump. These pumps are fixed displacement (piston type) pumps, and the only way to get more flow is to fit in a bigger piston. Like they do with audi / mazda etc pumps.
AWE A3 2.0T FSI Fuel Pump Upgrade
Old Mar 30, 2011 | 01:40 PM
Pyros777's Avatar
Lets look at it this way then. Given maximum drive to the pump, which pump would produce more pressure at the rail?
OK Vince and I are going to test it. As soon as I get the needed File and some good weather Ill try It out on E85. Will Keep you posted.
Old Mar 30, 2011 | 01:44 PM
07BoostedG5's Avatar
My thought exactly.
Old Mar 30, 2011 | 01:47 PM
jb09ss's Avatar
My guess is this will make no difference. As I said in my previous post, this pump is a fixed displacement pump, so when it pushes the fuel out, it goes out no mater what. With a bigger hole, it will be easier for the pump to push the fuel out, but the flow remains the same.
Old Mar 30, 2011 | 01:48 PM
It might or it might blow the fuel rail apart.
Old Mar 30, 2011 | 01:49 PM
Stamina's Avatar
lol There's a "HPFP Pressure Too High" code. It'll probably go limp before that happened.
Old Mar 30, 2011 | 01:50 PM
jb09ss's Avatar
And if it was that easy to modify the pump, don't you think that some vendor would have done the same and charged big buck for it?
Old Mar 30, 2011 | 01:51 PM
Stamina's Avatar
If it's a piston-type pump, then let's bore it!
Old Mar 30, 2011 | 01:55 PM
Who knows ? If they only made 3400 of our cars who would really care. Its fun to try different stuff out though
It looks like they made it tamper proof
Last edited by mongorat427; Mar 30, 2011 at 01:55 PM. Reason: Automerged Doublepost
Old Mar 30, 2011 | 01:58 PM
Bore it, stroke it port and polish it.
Old Mar 30, 2011 | 02:02 PM
Grishbok's Avatar
technologic.... technologic....
(daft punk ftw)
Old Mar 30, 2011 | 02:03 PM
jb09ss's Avatar
That is the solution. Problem is, you need to keep tolerances in the range of +/-0.00005" for each part. This is why the audi pump upgrade kit is 380$, for some parts that would be worth 5$ with normal machining tolerances.
I might of been strokin it when I thought of this.
Old Mar 30, 2011 | 02:07 PM
BYT*SS*TURBO's Avatar
I like it, let's hope it works out for you!!
You can ask Vince for a copy of Palmer and log it yourself
Old Mar 30, 2011 | 02:08 PM
[SIZE="2"]I it dosnt work I might take one of the other pumps I have and open the restricted hole up .0001 at a time.]
Old Mar 30, 2011 | 02:11 PM
Lunch and couch time
Old Mar 30, 2011 | 02:12 PM
jb09ss's Avatar
LOL, it's the internals you have to make bigger. Have you looked at the parts for the audi pump I linked in my first post?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
