How many running the LNF stage 2 cams?
Oh there's no doubt that your numbers are impressive and I'm convinced that me running e47 is the only reason I'm making 34 more horses.
As for running on the stock engine, I probably would be still as well if I hadn't spun my bearings on stock turbo ;-)
lol I know it's only numbers on a piece of paper, but that's what these records are. Quite honestly I'll be doing those fueling upgrades for safety and not for more power. But that doesn't mean I won't do a few dyno runs just to see what she could do
I'm only running 20psi at the road track anyways.
I'm only running 20psi at the road track anyways.Senior Member
well i figured starvation :P lol. but just dont see it happen much with these cars. i was kinda like wuuuttt? lol. but hmmmm, maybe i should look into this oil pan then since i plan on tracking it too. how was the block? able to hone it or was it toast?
The block, pistons and rods were fine.
Main bearings, rod bearings and crank shaft were toast and were replaced.
I took the opportunity to upgrade to forged pistons and rods in the process.
We also replaced the oil pump for safety just because of the amount of debris in the oil. Some of the metal chunks were an inch long!
sounds like stock bore so probably just honed it.
try to think of it this way:
boring = oversizing the bore to accomidate a larger piston; done for increasing displacement, or because of exessive clyinder wear which necessitates an oversized piston
honing = this is cleaning up the bore; this is done when ever you are going to be using new rings, so that they have nothing to catch on, and are able to seat properly.
It's always recommended to hone the cylinders when installing new pistons and rings. Without a fresh crosshatching the new rings will never properly seat and develop their our wear pattern.
I looked and can't find any videos of cars running these, are there just not many people running these cams?
I realize that cam phasing (when operating properly) will miimize the effect of lope/overlap ~ and I would expect that rolling in 5th @ 40mph/60kph would be jerky ~ but that's just because you're lugging it...
A part of me would love to just jump in head first... for the mean time, I'm content to see what everyone else is doing...
I looked and can't find any videos of cars running these, are there just not many people running these cams? I realize that cam phasing (when operating properly) will miimize the effect of lope/overlap ~ and I would expect that rolling in 5th @ 40mph/60kph would be jerky ~ but that's just because you're lugging it... A part of me would love to just jump in head first... for the mean time, I'm content to see what everyone else is doing...
It's called dropping a valve which causes the chain reaction and " clearance ". We're talking close tolerances here. If you tap a valve and it falls into the cylinder guess what happens next! Do valve springs help ? It's possibly the weakest link when ******* with the head , my personal experience says change valve springs if adding cams or reduce your timing if you're running aggressive regrinds. Or even just the fuel lobe cam. This is my personal experience. My first LNF lasted 45 thousand miles tuned and on e85 until it had the porous block issue which GM replaced the engine with an LDK " franken blocks" The engine lasted about 7 thousand miles with ZZP's fuel lobe cam and Intercooler.
Take it for what you will but it might save some people the hassle of rebuilding a once perfect LDK with a few thousand miles on it. Can't bitch engine was replaced under warranty , have a new block forged internals arriving soon .
The engine it was replaced with every once in a while made a " timing chain noise" on start up meaning possible oil starvation or something wrong with the engine from day 1. within a few months of having the new engine my warranty expired because I bought the car brand new in 08.
I think we can all agree that valve springs are always a must when installing more aggressive cams. I don't think anyone in here would be running larger cams on a stock valvetrain. An intake fuel lobe cam is one thing, but when going with higher profile cams I would hope its common knowledge to upgrade springs.
Turbo Johnny
Feb 21, 2019 09:41 AM
Sean Cummings
Mar 9, 2018 12:26 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
