How much boost?
Old Aug 27, 2009 | 05:53 PM
m0ore4ustin391's Avatar
How much boost?
Hey guys, was just wondering how much boost im supposed to be getting on my stock 2009 Cobalt SS/TC?
Old Aug 27, 2009 | 06:02 PM
09CobaltSS1's Avatar
safely/reliably or just max boost and who cares about possibly torching the turbo?
Old Aug 27, 2009 | 06:04 PM
PimpLay2's Avatar
15-17
Old Aug 27, 2009 | 06:05 PM
Acey's Avatar
On the first review of the SS/TC I read it said it can hit as high as 21 to make the 260 tq. Not sure if that's true or not.
Old Aug 27, 2009 | 06:07 PM
Originally Posted by PimpLay2
15-17
K good, thats what i have been hitting. Anyway to get more?
Old Aug 27, 2009 | 06:08 PM
slowstang's Avatar
It depends on the weather and altitude mainly. In the summer i've hit 19psi and in the winter as low as 13psi. The car was still faster in the winter on the 13psi
PimpLay2's Avatar
yea get it tuned.... you get a good 50hp/70lbs of torque
Old Aug 27, 2009 | 06:17 PM
Of course you can hit more.. Hence my question I asked if whether you are looking for safe/reliable higher boost numbers or just crazy boost numbers.... because you can technically pump 30psi out of that bad boy.. turbo might not last you very long if you constantly boost it that hard, but it can be done
Old Aug 27, 2009 | 06:39 PM
Definitely safe and reliable. Got to make this car last 5-6 years.
Old Aug 27, 2009 | 06:50 PM
You could probably run 21-22psi pretty reliably.. The stage 1 will be producing 21psi or so.. I just wouldn't push it to full boost constantly every time you drive it.. No one really knows how long these turbos will last in these cars just yet
Old Aug 27, 2009 | 11:31 PM
platinumrims's Avatar
yuh i want mine at like 20 then spike to 23 just before redline (at shift point)
Old Aug 28, 2009 | 09:26 AM
dthomp2366's Avatar
http://www.youtube.com/watch?v=6C9J7...layer_embedded
I touch 18-19 all the time. Still stock.
Old Aug 28, 2009 | 09:41 AM
Stamina's Avatar
You'll see higher boost at higher altitude and temperature (among some other things). That's crazy you're seeing that in DFW. I'm there sometimes and never see anything quite that high. I've been in mid-19psi before once after some of my mods.
I've been as low as 13 and as high as 19.5. Typically it seems to be around 15.Xpsi here in Houston. Charge piping/downpipe put me in the 17-19 range until it learned down. The K&N Drop-In pushed it back up to the low 16-17 range until it learned down again.
Mine is weird in the fact that sometimes it will do a mid-pull spike. I've got video of me up against some bolted and tuned GTI and you can see it sticking to 15-16 and after an NLS it went to 18-19 and I started pulling on the guy until it went back to 15-16. Don't know why that happened.
I'm at a point where the stage is set for a tune and the pull will be bonkers after that I bet.
Old Aug 28, 2009 | 09:49 AM
dthomp2366's Avatar
I'm in the same boat. I know with a tune I'll be night and day faster. Shopping downpipes and charge pipes now.
Old Aug 28, 2009 | 09:55 AM
Mine is wierd in the fact that sometimes it will do a mid-pull spike. I've got video of me up against some bolted and tuned GTI and you can see it sticking to 15-16 and after an NLS it went to 18-19 and I started pulling on the guy until it went back to 15-16. Don't know why that happened.
a tune is like night and day over stock.. it's definitely pretty bad ass.. That GTI wouldn't stand a praying chance against you at that point especially with the bolt-ons that you have..
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
