HP fuel pump
Old Apr 1, 2015 | 06:26 PM
crispino's Avatar
HP fuel pump
So my car has 60k miles and I have had to replace the high pressure fuel pump twice now, today being the second.. anyone else having bad luck with them? And how can I prevent it.. it has a stock tune..
Old Apr 1, 2015 | 07:37 PM
What oil are you running and what was the code causing the need for a replacement?
Old Apr 1, 2015 | 08:26 PM
crispino's Avatar
Low fuel pressure I forget the code number.. and currently 5w30 full synthetic royal purple, only because I got a case (6) 5qt jugs of it for free.. so I've been using that for about 4 months.. 2 oil changes
Old Apr 1, 2015 | 09:43 PM
Did the car also run like crap with the code? Because there is a code for lack of fuel pressure during WOT
Old Apr 1, 2015 | 11:56 PM
tomj77's Avatar
I hope ur running 4718 certified royal purple, if not drain it out of ur car right now and get proper oil. I destroyed a cam lobe using royal purple 5w30 full synthetic but not 4718 certified. engine started ticking a week after I put it in. the result, new motor.
Old Apr 2, 2015 | 01:43 AM
Ive also heard bad things about royal purple. Just use mobil 1.
Old Apr 3, 2015 | 07:14 AM
crispino's Avatar
Yes it's the GM Cert stuff I checked the bottles.. and yes the car ran like dog crap.. stutti ring and wouldn't Rev past like 2500.. the new pump fixed it but this has happened with 2 pumps.. I can't believe it
Old Apr 3, 2015 | 09:02 AM
Expensive as pumps too. Just buy an aftermarket pump thats stronger you dont need a tune to run it iirc
Old Apr 3, 2015 | 09:27 AM
WVU_SS's Avatar
Like others have said, I would never run royal purple again even if someone paid me. About a week after putting the GM certified stuff, I wound up with a pretty substantial hole in my block. Before that it caused some funky things to happen with the car.
Old Apr 3, 2015 | 10:04 AM
There are no aftermarket stronger pumps for the LNF high pressure fuel pumps
Old Apr 3, 2015 | 07:12 PM
KonnerTomlinson's Avatar
YET. HPFPupgrade is currently testing one they're making for us
Old Apr 11, 2015 | 06:58 PM
tomj77's Avatar
its interesting how u can search google and find so many storys from so many people with different cars, mostly boosted, that have pretty much the same storys as us. I would never touch that crap. I use mobile 1 or even better penzoil platinum. both have worked awesome in my car.
Old Apr 11, 2015 | 06:59 PM
tomj77's Avatar
u know if I was planning on getting say a new motor that was built, I would purposely put royal purple in my current one and drive around for a month just to prove what **** it is, and document it with video.
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
