installing dejon cp & hks bov..
I really like my dejon piping and my BOV I used that link on my install and I do not have a block off plate. I also did not retune and I have not had a code yet.
another thing is I am thinking about buying ZZP's upper rubber pipe for it to give it a little room for it to flex
yes do not touch the coldside leave it as is and see if you throw a code to waste your money unless you want a trifecta tune or hp...And beast if you want just cut the stock rubber that connects to your turbo from that pipe and use that
and the only difference from mine to yours sounds like im using a hks bov compared to your tial.... but that shouldnt matter. i didnt buy the mas relocater flange from dejon. wasnt sure if i needed to.
yeah just follow that its pretty easy just disconnect it from the turbo then the intercooler and slap the new one on...it might be a little difficult to get it off the intercooler just pull on it itll pop right off its cake really. Its alot easier if you jack up the front end also
ok I have dejone with HKS just do as the link says do not touch your bpv or any thing just put the dejon pipe on with the BOV and t the vac line. when you let off the gas it stops fuel that is my we dont need a tune got to love DI!!!
also this is basic stuff man
if you need help come out by me and ill help you. im about 45 minutes away. in all honesty maf relocation is the only way to go IF YOUR VENTING TO THE ATMOSPHERE or the car will spike rich.....leaving the bpv connected is just for those guys that want noise and it stills spikes rich just not as bad.
