installing dejon cp & hks bov..
have a 2010 ss t/c w/ gms1. looking at installing the dejon cp with the hks bov ssqv. the cp didnt come with the mas flange... wasnt completly sure if i needed it? trying to put to together if i need to get a tune after the install & how to install the parts. not sure if i had to purchase anything else or bypass anything, so i decided to wait and hear what u suggested before i went any further to reduce any possible problems.
dont really need anything else only need a mas on the cold side not hot side.and you wont need a tune you will throw a code for a mechanical bpv thats all i threw with my pipes and bov. and for the stock bpv you can leave it on or just buy a block off plate for it
im looking to run the same setup its gonna be on the hotside cp how do i change out the bpv or should i just leave it? also how would i run a vaccum line for it. the bov is going on the pipe that makes an angle to go around the engine on the right side if your looking at it standing in front of the car
the rubber seal goes between the bov and the flange of your pipe, and the metal ring is what holds the bov on the pipe...
ok thanks guys im about to order it soon but you dont have to cut the line that goes off the turbo right? also if i decide to go back to the bpv set up how easy is it to repair the area where the t goes?
