installing dejon cp & hks bov..
Old Oct 29, 2010 | 12:14 AM
  #76
whyyoumadson?'s Avatar
Originally Posted by dayhoff35
but your saying i should switch the bpv line and the one i have going to the bov
basically all im saying is i wouldnt have even touched the bpv. make sure its setup like stock. if you wanna go off the top part of the vacum block fine do it......cut the little hose like so....t it off run the cross section across to the line run the bottom part of the t fitting to your blow off valve hose.
Old Oct 29, 2010 | 12:28 AM
  #77
see what happens...ill check this is another few minutes...... then im off to bed. if you dont post back by then ill check it in the morning.
Old Oct 29, 2010 | 12:31 AM
  #78
chrisjaldin's Avatar
Originally Posted by efactor
sounds like your car is haunted. LOL
What the hell is that sound!
Old Oct 29, 2010 | 12:33 AM
  #79
turkey call on the bov
Old Oct 29, 2010 | 01:58 PM
  #80
dayhoff35's Avatar
i changed the bpv back to the way that it was i have to go get my tire patched now so ill see if it is still throwing a code if it is ill post new pics thanks for the help man
Old Oct 29, 2010 | 02:06 PM
  #81
HB_SS/TC's Avatar
Why don't you just get a block off plate and run ONE hose instead of using T's???
Old Oct 29, 2010 | 04:16 PM
  #82
PrincessTurbo's Avatar
Originally Posted by HB_SS/TC
thats cause I put a turkey call on it lol
LOL that **** is funny as hell dude , man I am still grinning .. Turkey call BOV
Old Oct 29, 2010 | 04:58 PM
  #83
dayhoff35's Avatar
I did what you said and no sound and then changed it back tighhtened everything disconnected the battery and no more code.
Old Oct 30, 2010 | 02:37 AM
  #84
so everything works a ok now? bov and all?
because if he does that he will throw worse of a rich spike with it blocked off then he will ifhe has the bpv running too......regardless a maf relocation is neccisary.
Last edited by whyyoumadson?; Oct 30, 2010 at 02:37 AM. Reason: Automerged Doublepost
Old Oct 30, 2010 | 02:42 AM
  #85
dayhoff35's Avatar
Ok so there was no code for a little then it came back on it says bpv is stuck shut is that normal? I'm tempted to just delete the light with my interceptors but idk how all that works
Old Oct 30, 2010 | 08:57 AM
  #86
do you have a spring in the bpv valve or anything or just the stock one? in all honesty you should just relocate your maf sensor and block off the bpv and do it the right way.
Old Oct 30, 2010 | 01:42 PM
  #87
dayhoff35's Avatar
The bpv is stock and how would I do the relocate?
Old Oct 30, 2010 | 02:44 PM
  #88
you need to have a maf pad welded onto the cold side pipe and the wires extended so you can plug in the maf sensor.then have a block off plate for the intake made.
Old Oct 30, 2010 | 05:56 PM
  #89
dayhoff35's Avatar
ok well i havent decided if i like the bov or not yet but if i switch back i assume it wont think that the bpv is not stuck right?
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Bohb
Sep 27, 2015 09:11 PM
