installing dejon cp & hks bov..
Old Oct 25, 2010 | 07:17 PM
  #51
Ch1ck3n's Avatar
Originally Posted by whyyoumadson?
if you need help come out by me and ill help you. im about 45 minutes away. in all honesty maf relocation is the only way to go IF YOUR VENTING TO THE ATMOSPHERE or the car will spike rich.....leaving the bpv connected is just for those guys that want noise and it stills spikes rich just not as bad.
This x10! If you get a VTA BOV without a MAF relocate, you are blowing metered air into the atmosphere. The car thinks it's there and it won't be, your car will run super rich and will most definitely F up your performance.
Old Oct 25, 2010 | 07:30 PM
  #52
paintballerr78's Avatar
thats weird cause my car runs perfectly fine with my bov without the maf relocation
Old Oct 25, 2010 | 07:40 PM
  #53
Ch1ck3n's Avatar
Do you have your stock bpv blocked off?
Old Oct 25, 2010 | 07:43 PM
  #54
no i have it hooked up still
Old Oct 25, 2010 | 08:15 PM
  #55
beast10007's Avatar
i am the same way as paintballer and my car runs just fine.
Old Oct 25, 2010 | 09:58 PM
  #56
ericgt79's Avatar
you just think so cus you cant tell the power your losing
Old Oct 25, 2010 | 10:09 PM
  #57
ssblackstealth's Avatar
corn gas ftw....
mines hooked up the same way as paintballers too, yea it works fine but i can tell theres more there....drove interviewatruins car with hks and maf relocate on basically the same tune as me and it felt much better...
Old Oct 25, 2010 | 10:25 PM
  #58
ya i plan on buying zzps lower cp and maf relocation when i get the money
Old Oct 26, 2010 | 12:18 AM
  #59
whyyoumadson?'s Avatar
paintballer....do you have a wideband?
Old Oct 26, 2010 | 12:20 AM
  #60
i have the rpd on my car
Old Oct 26, 2010 | 12:21 AM
  #61
HB_SS/TC's Avatar
Originally Posted by ericgt79
that sounds horrible
thats cause I put a turkey call on it lol
Old Oct 26, 2010 | 12:41 AM
  #62
yeeah i know...dont really know what it does because i didnt want one in the car when i bought it......if it pulls wideband af ratio watch it real close when it blows off.
Old Oct 26, 2010 | 05:45 AM
  #63
chudson91's Avatar
exactly right. if you leave the stock bpv hooked up and the hks you will be a little better without tune. but you will have a rich spike. when i had my tial q on my car right waiting on my lower cp with maf, my car would hit around 11.5 11.8 afr when dd shifting. so yea you do need a tune but even better with tune and maf relocation. this car meters that air from the bpv. you cant just say that when you throw that air out that it will be fine.
Old Oct 26, 2010 | 06:09 AM
  #64
Sp33dyG's Avatar
lmfao!!! epic!
Old Oct 26, 2010 | 11:08 AM
  #65
yep....the offer stands. you need help with the install come by.
Old Oct 28, 2010 | 09:54 PM
  #66
dayhoff35's Avatar
I just installed mine relocated bpv as shown in the thread on page 1 but I have code p2261 showing any ideas on what caused it?
Old Oct 28, 2010 | 11:51 PM
  #67
relocated bpv? what? you mean maf sensor?
Old Oct 28, 2010 | 11:54 PM
  #68
p2661 is a code for the turbo bypass valve is stuck closed. if you have it blocked off you are going to throw it.
Old Oct 28, 2010 | 11:55 PM
  #69
dayhoff35's Avatar
install pics for seeing if it was right
i did the lne that was on the bpv and put it to the filter then to the nipple on bov
then took a line and ran it from the bpv nipple to the top of the T
then ran the line pointing towards the engine through the T
was ths correct and everything?
Old Oct 29, 2010 | 12:04 AM
  #70
looks like its wrong to me.....hook the bypass valve back up the way it was....the filter should only be on the line from the hks to the vacumm block not the line for the bpv. leave the stock bypass valve routing alone.
the way ive seen the bovs ran like this done is if your looking at the vacumn block the one fitting to the left.....t off that and hook one to the bov, one to the vacum block and then the hose that was originally attached the the vacum block.
Old Oct 29, 2010 | 12:06 AM
  #71
take some better pics too so i can see the line setup more clearly aswell.... i cant really tell what lines are going where......all i can see is the filter from the hks getting routed to the bpv which shouldnt be the case.
  #72
dayhoff35's Avatar
this how to showed it the way iahd it set up i think https://www.cobaltss.net/forums/forc...thread-204185/
Old Oct 29, 2010 | 12:10 AM
  #73
post better pics so i can see your line routing...that kids car was a mess when i worked on it(he did that himself) he doesnt know anything about cars......
Old Oct 29, 2010 | 12:11 AM
  #74
dayhoff35's Avatar
but your saying i should switch the bpv line and the one i have going to the bov
Old Oct 29, 2010 | 12:12 AM
  #75
only thing that looks different from the pics is how he has the lines from the t fitting
