Intake Camshaft Sensor.....any GM techs out there?
Old May 14, 2009 | 12:11 AM
80vetteL82's Avatar
So a while back there was a lot of talk on here about the Intake Camshaft Sensor on our engines leaking oil. I know a lot of people, myself included, got the sensor replaced under warranty. I know a lot of people's have begun leaking again. I checked mine today and it's as wet, if not more, than it originally was with oil.
Does anybody know if GM has come out with a permanent fix for this yet? Anybody on here a GM tech with some better info? Im planning on bringing mine back into my dealer just so its on record that its still a problem. Its really saturated with oil and thats ridiculous for a new car.
Old May 14, 2009 | 09:19 AM
JerseyBeastBalt's Avatar
i had mine replacedin like the early part of april but when it was done my friend who just happens to be a tech put a little RTV on it...so far so good
Old May 14, 2009 | 12:43 PM
mduffy717's Avatar
im a tech at gm. i also have the cobalt t/c. mine was leaking as well but its not the sensor thats leaking. its the gasket and seal from the high pressure fuel pump. replaced mine which was on back order by the way and havnt had a problem since. that was about 3000 miles ago
Old May 14, 2009 | 04:35 PM
80vetteL82's Avatar
So what did you replace? The gasket and seal? Supposedly my dealer replaced the sensor....its been probably 3-4mos and now its leaking again.
Old May 14, 2009 | 06:13 PM
mduffy717's Avatar
the high pressure fuel pump is rite above the camshaft sensor. where that bolts in is a gasket and inside is like an O-ring seal. thats what you need to tell your dealer to replace. it leaks from there down to the camshaft sensor
Old May 14, 2009 | 06:48 PM
Cobaltss/TC's Avatar
i am always checking this and no GM has yet to send us any info on the other 3 i have replaced
Old May 14, 2009 | 07:15 PM
tomj77's Avatar
i need some pics, where do u look for the fuel pump and cam sensor, i wanna check mine. tried to find it once, have no idea where it is
Old May 14, 2009 | 09:14 PM
80vetteL82's Avatar
So youre saying its actually the fuel pump gasket leaking?
Old May 14, 2009 | 10:33 PM
MaxVQ35DE's Avatar
Can we get a part number?
Old May 14, 2009 | 10:38 PM
Maven's Avatar
No there is no news from GM, and YES it is the Intake Cam Position sensor on probably 95% of cars, RTV fixes it.
Old May 15, 2009 | 09:41 AM
Terminator2's Avatar
My high pressre fuel pump gasket was leaking too. I used black RTV on it and it no longer leaks. I also did my cam sensor too. Finally, no more oil leaks on this thing.
no_ss
Oct 18, 2015 11:58 PM
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
OrangeCoba
Sep 25, 2015 06:06 PM
