Introducing Trifecta ECP- BIG NEWS
We've been working on this for well over a year and we've spent lots of time testing and ensuring it's correct, but we've finally nailed it down and it's almost ready for production, and we're really proud of what we've come up with.
I'd like to introduce Trifecta ECP, or Enhanced Charge Prediction.
As everybody knows, one of the biggest challenges in modding LNFs, is tuning them for various intakes and especially blow off valves (BOVs). These mods can result in sporadic setting of P0101 codes (or other fuel related codes) and disabling of boost (or limits to 3psi) largely due to the sensitivity of the airflow sensors on these vehicles.
We've come up with some completely new tweaks that work with the vehicle sensors to allow for more wider variety of operating conditions when they report the data to the ECM. These new tweaks solve several problems that have plagued the community for a long time, including different intakes throwing codes and requiring re-tunes based on how the air filter is rotated (think the K&N SRI), not being able to run an atmospheric blow-off valve without relocating the MAF, and even then having trouble with the car not running right and hitting limp mode all the time.
So far the test results are very promising - we went out and broke every single intake rule there is for the LNF without ANY DTCs, CELs or boost limp mode. You'll be able to run a BOV with no problems, be able to run any intake you want without needing a re-tune for it. You could literally run a piece of pipe and a sock monkey as your intake and it would run fine. (We don't recommend doing that)
And here's the best part- If you already have a Trifecta tune AND own a Trifecta cable, this update will be 100% FREE. (your local dealer may charge you at their own discretion. If you do not own a cable and need to rent one, you can do so at the normal minor re-tune cost)
Now as I said earlier, this is NOT ready for production yet. We're in the beta test stage. So we need you- people with persistent P0101 codes, people running atmospheric BOVs, and people having limp mode issues related to intakes or other charge issues- to test this out. If you own a Trifecta tune and a Trifecta cable and fit the criteria above, please reply to this thread and we'll contact you. You do not need to own a Trifecta cable if you live in south florida and are willing to drive to me to get this installed.
You have an LNF...you should know better
The implication here is that the MAF is being circumvented. This is otherwise known as Speed Density tuning. Cars have been tuned this way for years, but never with such an advanced ECU as the one in the LNF (E69).
Trifecta has taken a huge step here. Time will tell, but given the fact that Vince owns an LNF-powered vehicle, and a BOV, and sock monkeys, chances are once this hits production it will be spot-on.
The implication here is that the MAF is being circumvented. This is otherwise known as Speed Density tuning. Cars have been tuned this way for years, but never with such an advanced ECU as the one in the LNF (E67).
I like the way you think sir!
It basically more or less works off of air mass calculations through the map sensor(s) and volumetric efficiency.
No such tables exist for the lnf unfortunately, however they do for basically all other gm ecm's.
Edit: No such tables are accessable through HPTuners at least. Everything is basically tuned via air loads, and through the maf.
Well its not really SD. Thats just kind of what it resembles based on BNR's post. As far as I can tell this is something all new.
NM, found a nice quick read
http://goo.gl/OLH2q
So Speed density is the ECU comparing RPM and volume/pressure/temp of incoming air.
Seems like this would help a lot especially when considering variations in setup. (air leaks, reading points etc) Which i guess is exactly what you said in the op
http://goo.gl/OLH2q
This is not available using HP Tuners and probably never will be. It has nothing to do with tuning ability, these tables are not available through that software. Much like how Trifecta pioneered E85 on the LNF, and HPTuners had to develop something for their users to be able to do the same. Though I doubt HPTuners will develop anything to answer this with since this is essentially a dead platform to them since the cars aren't being made anymore.
We actually tested this scenario. You lose boost but the car still runs. Basically the same as if it blew on your current tune.
