Introducing Trifecta ECP- BIG NEWS
Old Jun 8, 2012 | 01:05 AM
  #51
Projekt's Avatar
*looks around*
Where's Jordan - and what are you doing posting under his profile?
Jordan, you have yet to come across as the peace-maker type...
...and for the record, my intent was not to bash persay, moreover I was hoping for the slandering to cease.
I have had a change of heart lol.
  #52
DiabeticKripple's Avatar
im here! haha just messin.
this sure looks good for the lnf's
Old Jun 8, 2012 | 01:21 AM
  #53
soundjunky's Avatar
B.S.
Old Jun 8, 2012 | 07:30 AM
  #54
CudaJoe's Avatar
This is really cool. The one thing the LNF platform always needed was to do away with the friggen MAF sensor. Tuning by Manifold air pressure is the way to go.
I believe this also means that if a stock LNF were to be tuned by this, aftermarket mods added later may increase the horsepower, at least more substantially than the original setup lol.
Old Jun 8, 2012 | 07:46 AM
  #55
theamericanautos's Avatar
subd
Old Jun 8, 2012 | 08:42 AM
  #56
RobSSsedan's Avatar
I should've bought the cable...
Old Jun 8, 2012 | 10:26 AM
  #57
Dart_SI's Avatar
It'd be great if this could be made to work with hptuners.
Old Jun 8, 2012 | 10:54 AM
  #58
BNRacing's Avatar
Yeah this thread isn't about who tunes better, it's about the features of the software. No need to compare tuning abilities of anyone in here. I appreciate you guys keeping it civil.
Old Jun 8, 2012 | 10:55 AM
  #59
BNRacing's Avatar
I don't know that it wouldn't. It may be a similar situation as we had a couple years back when Trifecta had access to more tables than HPT and BYT was doing those layer tunes. This might work the same way.
Old Jun 8, 2012 | 11:51 AM
  #60
Dart_SI's Avatar
Well if it is (like the combo tunes) and if the ECP works like u say, it will be an insta-buy. Lol.
Old Jun 8, 2012 | 12:12 PM
  #61
sponge14's Avatar
Originally Posted by Stamina
All cables work on the LNF. Some of them don't work with the LSJ though.
Why would I spend $200+ on a cable when the Red one for $150 will work?
Old Jun 8, 2012 | 12:30 PM
  #62
ei3dag3's Avatar
agreed.
i spoke with vince about that exact subject 2 years ago haha.
i'm going to be beta testing this today.
will post more info later/vids and how the car runs.
in theory this should allow for turbo swaps and all that with the on the fly ecm adjustments based off the iat, map and 02 sensors. i'm excited.
too bad our os/ecm doesn't support alcohol o2 sensors or we'd able to go back from e85 to 93 with ease.
Old Jun 8, 2012 | 02:37 PM
  #63
Stamina's Avatar
lol What?
I may be misunderstanding what you meant, but I said that your red one would work fine, so no issue.
In my case, I've got LSJ customers and such too, so I can't use the Tactrix, for instance.
Old Jun 8, 2012 | 02:48 PM
  #64
Frogstofall's Avatar
Originally Posted by interviewatruins
agreed.
I think this is still possible in some way, shape or form. There has to be a way to integrate the signal from am ethanol sensor into our setup. May require some extended hackery though. I think with enough money, Vince would find a way.
Old Jun 8, 2012 | 03:11 PM
  #65
ei3dag3's Avatar
its not unfortunately.
our ecms don't have an input for it.
Old Jun 8, 2012 | 03:13 PM
  #66
ei3dag3's Avatar
uploaded the ECP tune.
it's still in beta. I'm awaiting to hear back from vince on what he sees as far as results go.
everything idled and started just fine.
here is a video/pull....err as good as I could get it with one hand.
i took a lunch and drove to mexico.
Cobalt Ss ECP TUNE - YouTube
Old Jun 8, 2012 | 03:21 PM
  #67
Projekt's Avatar
Im also still waiting on Vince for the revised file. But to be honest it pulls soo much better now that this tune fixed my P0101 ISSUE.
Old Jun 8, 2012 | 03:28 PM
  #68
ei3dag3's Avatar
interesting.
i didn't have any maf issues.
i should have unplugged the pigtail going to the sensor to show that it really wasn't reading off the maf and there was no engine code.
you know...for the naysayers.
i can understand why it runs better though. that po101 would make it run like pewp.
Old Jun 8, 2012 | 03:29 PM
  #69
Projekt's Avatar
interesting.
Yes and its done that for a year. I put a smaller filter on (i ordered the wrong one) on my dejon intake and it sent it for a loop. now...its fixed.
Old Jun 8, 2012 | 03:42 PM
  #70
Ch1ck3n's Avatar
I believe Vince already overcame that issue. While troubleshooting my car he found a table that explained that relationship and can now manipulate the knock sensor sensitivity to a point. He made the tweak on my tune and I haven't had trouble since.
You are referring to the one that tended to come up with respect to using E85 or some big turbos, right?
Yeah, I've been having some troubles fighting off KR with my big turbo setup on hptuners.
Old Jun 8, 2012 | 03:46 PM
  #71
Terminator2's Avatar
Knowing what I know about the complexity of the E69 controller in the LNF I am very curious as to how this works. Speed density on an LNF could be done but with 600 tables in the ECM that control fueling it is not like SD tuning a LS series car.
I have seen 8 different LNFs with P0101 codes and in each case the cause of the P0101 was a boost leak. SD tune will just be a bandaid if you have a boost leak.
Old Jun 8, 2012 | 03:56 PM
  #72
With enough money it can happen.
Old Jun 8, 2012 | 04:23 PM
  #73
Stamina's Avatar
Yeah, the knock sensor sensitivity goes up with load if I remember right (it may have been the MAF tables... it's been a while since I had talked about it with him), so skewing load will crank up your knock sensor sensitivity to where it'll sometimes be hearing things that aren't really knock. This in turn causes driveability issues because it randomly pulls timing when there's no need to.
When scanning with my Dashdaq a while back, it revealed that there are Speed Density capabilities within the ECU. I'm wondering if that's what it falls back on when it goes into limp or malfunctioning/disconnected MAF modes. Perhaps he found a way to force it into that mode while making it more than just open loop.
I haven't been working with Vince on this particular project, so that is my own speculation.
Old Jun 8, 2012 | 04:30 PM
  #74
BNRacing's Avatar
Although this may not be a possibility, we have been toying with the idea of select-a-gas
basically select-a-tune but instead of low boost you'd have 91/93, instead of high boost you'd have E85
Old Jun 8, 2012 | 04:33 PM
  #75
Stamina's Avatar
...But then we're back to the single tune days effectively. If Vince were to roll that out, he'd be best off to have a second way to switch the fueling so people don't give up their DD-mannered vs. power-focused tune selectability.
