Introducing Trifecta ECP- BIG NEWS
Old Jun 18, 2012 | 03:08 PM
  #126
nobody2u's Avatar
Here's hoping!
Old Jun 18, 2012 | 03:32 PM
  #127
cubaniche's Avatar
Originally Posted by Stamina
We'd also need somebody with an atmospheric BOV, MAF relocate, etc. to get some info to show those areas as well. Mine might need some tweaking at first too, because of the heads and cams.
I wanted to do this but WOT is not an option for me right now so, testing would be limited.
Old Jun 18, 2012 | 04:07 PM
  #128
09CobaltSS1's Avatar
..And to clarify: This is nothing against Vince at all. I'd just have a hard time sometimes selling a feature that nobody has any physical/recorded findings behind is all. Some people I've dealt with don't care at all about the technical aspect of how it does what it does, but only the benefit aspect of what is achieved by doing it. I have to appeal to both kinds of people.
I'm sure Vince looked into this initially because he saw promise, and then began rolling it out when he saw that benefits had been achieved by doing it. I'm just asking for something in the public domain I can point to and be like "Here, Mr. Customer, this is an example of what this feature does for you."
Like I said, if this isn't going to be possible, I can test it out and try logging it if nobody else can. Who knows, maybe it's so good that I'll have a 0 pegged fuel trim all the time.
i know a while back Vince had been trying to work with a 3rd party software company (Palmer Performance) to impliment their data logging software into his Trifecta software. This would allow LIVE monitoring while recording a data log for Trifecta which could also be viewed in ScanXL (one of Palmer's products) as a log file so you can see data graphs, charts and hystograms. I'm not sure how far along that came, but I definitely think it would be beneficial on both his and the customer's end to have this capability.
On the topic of ScanXL, this is actually the data logging software I was refering to a few posts back. I had been using this software to monitor things back when I was Trifecta tuned, which for me ended up being very much worth the $250 I spent on it (ScanXL Pro+GM Enhanced Add On). It's definitely not for everyone, and there's definitely a learning curve to figure out, but it particularly can help dealers out with their end of things.... assuming they know what they're looking at of course..
Old Jun 21, 2012 | 02:16 PM
  #129
Stamina's Avatar
Just to repeat: This is still in the testing phase. Use caution when testing with engines of different VE.
In the interest of full disclosure:
I tried ECP last night on my car, and did not have good success. My head and cams were probably throwing off the airflow it would normally expect I'm guessing. Sent in some logs to Vince. Will see what he says. Hopefully we'll be able to work on some things to make it run like a top.
Car showed I was getting 6MPG standing still at idle, LTFT dropped to -13 (the tune that this ECP tweaked tune was based off of is normally zeroed out) and jumped up on tip-in, would go lean on tip-in before catching itself, bucked and stumbled at low RPM and low load, AFR was rolling all around, and possible audible knock on one occasion.
I feel we still have some things that need to be worked out on this for modified engines that are beyond bolt-ons. Hang in there while we work these out.
Old Jun 21, 2012 | 02:21 PM
  #130
Terminator2's Avatar
Car showed I was getting 6MPG standing still at idle, LTFT dropped to -13 (the tune that this ECP tweaked tune was based off of is normally zeroed out) and jumped up on tip-in, would go lean on tip-in before catching itself, bucked and stumbled especially at low RPM and low load, AFR was rolling all around, and possible audible knock on one occasion.
Yes mods like ported head, cams, etc will change VE values so big changes will have to made to the VE values.
Old Jun 21, 2012 | 04:23 PM
  #131
soundjunky's Avatar
Just to repeat: This is still in the testing phase. ....
oh?
Originally Posted by BNRacing
We've got a lot of feedback and we're happy with it. ECP is officially released to the public, and guess what? For those of you that don't have a tune and want ECP for your LNF, we're having a group buy to kick it off.
*shrugs*
Has anyone with this tune on a basically stock setup (no mechanical engine changes) dynoed this yet?
I've been awaiting some clearer info from Vince... but between his move & what not, I don't think he's had sufficient time to answer my questions....
(hint: if you're a dealer go onto WOT-Tuning)
Old Jun 21, 2012 | 04:29 PM
  #132
casionerd's Avatar
village idiot
Originally Posted by casionerd
So if we have a Trifecta tune and a cable but no codes are being thrown and AFRs and everything look good.... should we go ahead and get the update???
Old Jun 21, 2012 | 05:46 PM
  #133
Stamina's Avatar
Released and testing are two different things. People beta test released software all the time, at their discretion. That doesn't mean it's in its final revision yet. Even if it was, we all know that software makers come out with patches all the time after release to fix things.
I worked as a Beta OS software engineer back in the day, and just because Microsoft, for instance, released a new snazzy server OS, doesn't mean that it was ready for prime time. Linux-based stuff was even worse back in the day. They had a new build every week it seemed for several different flavors.
This also seems to be a corner case, where it only affects heavily/internally modified engines, so that's another thing to take from this.
Old Jun 21, 2012 | 06:01 PM
  #134
ei3dag3's Avatar
my car has been back firing.
it performs faster.
a/fr's seem to be okay.
gauge isn't showing knock. but it is def backfiring when rpms go down or when i shift into 2nd gear.
think im going back to my old tune.
Old Jun 21, 2012 | 06:04 PM
  #135
soundjunky's Avatar
it performs faster.
Thank you for these posts guys - they have helped me form a decision in the absence of Vince's response...
Old Jun 21, 2012 | 06:34 PM
  #136
Stamina's Avatar
it performs faster.
Wow, ok. I didn't know you were having issues too.
Yeah, I went back to my old one for the time being too, until it can be worked out.
Old Jun 21, 2012 | 09:06 PM
  #137
BNRacing's Avatar
Can you guys please data log it back firing so we can check it out? We did a lot of extensive testing and everything was fine. So if you guys are having any issues, please take a data log of the car having the problem while the logger is running and send it to me at customersupport@badnewsracing.net
This is still sorta beta phase right now, it's not being sent out unless requested so we can get some real world testing, so I do want to thank you guys for testing it and helping out.
Old Jun 21, 2012 | 09:29 PM
  #138
Stamina's Avatar
My logs (I did a before and after ECP log) are already in the system, under ticket number 1646.
Old Jun 21, 2012 | 10:32 PM
  #139
So your update should be ready by about.. ohh... give or take... 2 weeks?
Sorry had to do it..
Old Jun 22, 2012 | 12:23 PM
  #140
ei3dag3's Avatar
i'm a dealer and have already done datalogging for vince.
he said it looked "okay."
i'm just gonna go back to my original e85 tune till this guy is out of beta.
its weird too, when i shift to second it shifts hard once I release off the clutch due to the backfire.
i do like the tune because it is faster, but that can't be good on my car.
Old Jun 22, 2012 | 12:38 PM
  #141
cubaniche's Avatar
Hope it gets figured out as I was wanting to be able to keep my BOV as VTA and this seemed like a good option.
Old Jun 22, 2012 | 01:47 PM
  #142
BNRacing's Avatar
Did you log it doing the problem?
Old Jun 22, 2012 | 02:46 PM
  #143
Does the tune have any changes other than the ECP? Because it should not be any faster unless something else is changed assuming your MAF calibration and correction tables were properly dialed in in the first place. Good or bad MAF tuning can really make or break a tune IMHO.
Old Jun 22, 2012 | 02:47 PM
  #144
SSlobalt's Avatar
Oh, BURN!!!!
Old Jun 22, 2012 | 03:12 PM
  #145
ei3dag3's Avatar
yea, it was doing it when i logged it but i didn't really pay attention to it.
2 weeks later I know exactly when and how it happens so i pay more attention to it.
i'll do another log for vince and email it to him before I put my old tune back on.
Old Jun 22, 2012 | 03:13 PM
  #146
ei3dag3's Avatar
afaik it shouldn't.
he simply asked me if i was still on my e85 file.
i said yes and then got this ecp tune.
to me it feels faster. i'll report more on that when i go back to my original tune.
Old Jun 22, 2012 | 03:21 PM
  #147
Stamina's Avatar
Oh, BURN!!!!
Hey, I did my part. The ball's in Vince's court now.
afaik it shouldn't.
Yeah, in my case he asked me about which tune revision I was on and if I was the last E85 one he sent me, so I assumed that he then did an ECP conversion to my current tune.
Old Jun 22, 2012 | 03:23 PM
  #148
SSlobalt's Avatar
Yeah. I think that's what SS is talking about.
Old Jun 22, 2012 | 03:27 PM
  #149
Stamina's Avatar
Yeah... Don't mean to bash, but it's been that way recently. :/ To be fair, he's in the middle of a move right now. On that note though, if I was moving, my job would still expect me to keep up with everything. :/
Old Jun 22, 2012 | 03:46 PM
  #150
Not sure if it applies to you but anyone on full E-85 without cams and/or a 5th injector you guys are nuts. Even with cams once you get to ~370 whp and 440 wrtq (25 psi) stock turbo that is the edge of injection window misfire and rail pressure dropping. Guys at high altitudes can get away with it because reduced airmass means less fuel being used.
