its bad... really bad...
Old Apr 1, 2010 | 05:56 PM
cardelino18's Avatar
well italianjoe is working on my car changing the pistons and this is what he found out...
http://s818.photobucket.com/albums/z...t=P1060428.jpg
and it should look like this
http://s818.photobucket.com/albums/z...t=P1060433.jpg
what we are going to do is send the block to Darton for them to have put sleeves in, bored out to stock bore and put in the new wisco pistons... and hopefully after that ill get my car back...
Old Apr 1, 2010 | 05:58 PM
Killa702's Avatar
ouch man, good luck
Old Apr 1, 2010 | 06:29 PM
cmiller8006's Avatar
Let me know on the cost of having it sleeved.
Old Apr 1, 2010 | 06:37 PM
1500 sleeved to the stock bore size... plus shipping
Old Apr 1, 2010 | 06:39 PM
Rissa's Avatar
What happened to your car....damn.
Old Apr 1, 2010 | 06:43 PM
fakameanrepresent's Avatar
doesn't look good.
Old Apr 1, 2010 | 06:47 PM
Tennpenn83's Avatar
sorry to see that. keep us posted
HB_SS/TC's Avatar
I wonder what mine looks like...
Old Apr 1, 2010 | 06:48 PM
MaxVQ35DE's Avatar
Gods way of preparing you for a turbo upgrade
Old Apr 1, 2010 | 06:49 PM
Billy Baldone's Avatar
Just curious if you even tried taking it to the dealer for warranty work?And I don't want to hear "pay to play"...blah blah blah... our asshat president made sure we all own GM so none of those comments are necessary.
Old Apr 1, 2010 | 07:16 PM
fredds-turbaltSS's Avatar
could you just bore it out? or do they only make factory bore sizedd pistons? they port the head big turbo big hp
Old Apr 1, 2010 | 07:32 PM
ItalianJoe1's Avatar
Lol @ how true this is.
I advised him, the only real route to take in his case is a full sleeved block. No sense using stock stuff if you plan to push real power. It will still break. The Darton or Bates setup is basically bulletproofing the lower half of your motor.
No sense boring the stock block if you plan to make power. The sleeves are too thin as is. Removing more metal doesn't help.
Last edited by ItalianJoe1; Apr 1, 2010 at 07:32 PM. Reason: Automerged Doublepost
Old Apr 1, 2010 | 07:47 PM
Boosted_Cobalt09's Avatar
i tried advising him of this along time ago lol.......also advised not so huge of a turbo with a cast stainless manifold either lol. oh well atleast hes getting it taken care of and building the motor.....
Old Apr 1, 2010 | 07:50 PM
mkriebs's Avatar
Have you planned a lower block girdle? I am curious to see how much the block holds before it cracks from flexing.
Old Apr 1, 2010 | 08:32 PM
Do you know how much for just the sleeves? I have a pretty reputable engine shop near me.
Old Apr 1, 2010 | 08:36 PM
EcoTecDriver's Avatar
Old Apr 1, 2010 | 08:37 PM
09blackonblack's Avatar
sleeves are easy to install... if you do it fast... freeze overnight in a freezer and have your engine block warmed up ie setting by a heater work REALLY fast and drop them in
Old Apr 1, 2010 | 08:51 PM
mron0903's Avatar
yea that's a great idea!.........
get it properly done by a good machine shop.
Old Apr 1, 2010 | 09:05 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
You are totally correct giving that advice.
I have had 2 blocks sleeved and when you see pictures of the process, there is more work than you think. Popping out the stock sleeves is the least of the work. Boring out the block to accept the work needs to be done by at least a good machinist and preferably with a CNC machine and this is a 3 day process. The sleeves then need to be installed and you get one chance and back yard mechanics don't qualify. After the sleeves are in they need to be CNC bored out to match the actual pistons so the pistons should be provided at time of the sleeves being installed.
After all of that new mainstuds should be installed (longer than stock bolts) and those studs should be line honed.
If someone can do all of this in their back yard they own a really nice shop and have some crazy skills.
On a side note, the Bates sleeves were designed for GM Racing and have a bigger lip on them (as well as being beefier) than the Darton sleeves. My DD is running the Bates sleeves installed by Bates himself and it was worth every penny.
Old Apr 1, 2010 | 10:22 PM
HHRSSouth's Avatar
Perfect time to go 2.4, stroke it
Old Apr 1, 2010 | 11:07 PM
mmcgee123's Avatar
sleeves arent hard to put in its like puting a semi floating wrist pin in u freeze the sleeves for a while 4-6 hrs then heat the block to operating temp
Old Apr 1, 2010 | 11:56 PM
Stock sleeves maybe. Not aftermarket. Look up the machining that's done to go to an integrated deck sleeve.
Old Apr 2, 2010 | 12:52 AM
nicely said
i dont believe we have the deck heigh for a 2.4.....i believe a 2.2 or 2.3 is the largest we can go.
Old Apr 2, 2010 | 01:05 AM
mkriebs's Avatar
We can use the 2.4 crank, but that will only give us I believe just over 2200 cc's of displacement on the stock bore, 2 sizes larger should give us just over 2300 cc's, and with sleeves, I think 3 sizes over should qualify as a 2.4L (2380+ cc's). I did all the math at one point in time, but it was a while ago, and my wallet has since dismissed the idea.
BUT, the moral of the story is the LE5 crank WILL, in fact, work in the LNF block. Now, if it is any better, or stronger than the LNF block is to be determined. I know the build book gives the specifics for the 2.2 crank, but I do not think it gives the LE5 crank ratings. Though, you could always have a billet one made ($$$$$$$), or get the OEM one cryo treated. Cryo treating gives something like 18%-30% more strength to a component, which may not sound substantial, but it really is. You figure, the LE5 crank is good to probably 500hp, add 18% more to that, and its close to 100 more hp that it can handle, for relatively cheap. Sorry for the longevity of this post, just thinking out loud really.
Also, I am curious if you are getting the block decked, or running a girdle, or anything to beef up the bottom end of the block itself?
Old Apr 2, 2010 | 01:09 AM
The bottom end is pretty much a girdle already, not much more to do there. I suggested to Fabian that we cryo the crank while it's out, I know of a place very near to me that's reasonable. Considering this build is already way over what he wanted to spend, doing a bunch of part swapping to create some oddball bottom end is not a good idea at the moment. I believe the block has to be decked with the sleeves, I'm assuming Bates will handle that.
