Just curious... What's your input?
Old Apr 6, 2011 | 10:04 AM
Gremlin85's Avatar
So HPTuners came out with new parameters unlocked for the amazing LNF. So I got to tinkering, playing, learning and finally doing a set tune.
First, my currrent mods: I have Dejon upper and lower charge pipes, Gutted stock DP, K&N SRI, gapped new stock AC Delco plugs to .032 and the FORGE BPV. I've had all these mods on for a while (probably 15,000 miles).
Now this new tune I have taken a lot of time to get right and I've been happy with the results so far. I'm just looking around to get everyones input and to see what you all have to say about what I've done, doing and am planning to go.
After street and dyno tuning I was putting down 318WHP and 381WTQ... dialed back a little to around 310-ish WHP and 361WTQ because boost was spiking up to 29-30PSI! I have the boost ramping up from 18PSI and then it'll peak to about 25PSI... as RPM's climb it'll hover 23-ish and tapper off to about 20PSI at 7000RPM. I've noticed, however, that depending on gear VS. rpm VS. road speed and load the boost will ramp up to about 27PSI and hold until redline where it will taper off again.... That worried me a little. I have NOT gone past 60% throttle since tuning was complete. Now, with all this added boost and new found power, I am only able to run a degree or two more timing up top tan stock which I am slightly disappointed with but I understand why.
I am planning on doing pistons and valve spring for next summer. I want to do an intercoooler this summer.... Maybe a different turbo after all that.And maybe a REAL catless DP lol. My goal is 400+WHP when all is said and done.
So CobaltSS... Whatcha thinkin'?
Old Apr 6, 2011 | 11:03 AM
Gremlin85's Avatar
235 views in 1 hour... not one comment. LMAO.
Old Apr 6, 2011 | 12:05 PM
Sweetsandman's Avatar
What are you curious about? Whether or not to get a big turbo? If you're looking for 400+ WHP, then Yes.
Old Apr 6, 2011 | 12:39 PM
umrdyldo's Avatar
I wouldn't run that much boost for long. Your piston or rings will go POP.
Old Apr 6, 2011 | 01:13 PM
Gremlin85's Avatar
Well, that and wondering how my numbers stack up.
Thats why my next major mod will be pistons. Most likely weisco. I read a lot about the ringlands giving out if pushing over 25psi.
Anyone have recent stories or experiences with ringland failure? Only way to tell is dyno numbers and compression and leakdown tests?
Old Apr 6, 2011 | 07:06 PM
boost_junkie16's Avatar
My LSJ suffered ringland failure. Massive amounts of blow-by.. Enough that it was blowing oil out my dipstick making a wonderful mess under my hood
Old Apr 6, 2011 | 07:39 PM
ronn's Avatar
keep that up and those future *plans* will become a necessity in no time.
Old Apr 6, 2011 | 07:48 PM
DiabeticKripple's Avatar
bump for a good guy
Old Apr 6, 2011 | 08:01 PM
AndrewSS/TC's Avatar
You can afford HPT but not a $159.00 downpipe? Lol JK
I can't wait to get real power with my car
Old Apr 6, 2011 | 08:13 PM
BBC21's Avatar
Quick question? I don't mean to steal the thread but howmis the figment with the dejon piping and everything?
Old Apr 6, 2011 | 08:19 PM
blewis13's Avatar
Lol agree with him ^. And I also think you need updated #'s in the sig .
Old Apr 6, 2011 | 08:32 PM
Ch1ck3n's Avatar
Honestly, You're better off lowering your boost and increasing timing, you'll see just as much, if not more power with less boost and be much safer overall. I ran 16* of timing up top @ 18-20psi on 93 octane last summer and saw similar numbers with an almost stock intake/exhaust less a downpipe and K&N drop-in.
As far as 400whp goes, gotta go big(ger) turbo unless you want to run Nitrous/E85 tune. 400whp pushes the K04 way out of it's efficiency range, and at that point you're just creating heat.
Old Apr 7, 2011 | 09:23 AM
Gremlin85's Avatar
When I first got the car, the first thing I did was hollow the cats out and basic HPT tune lol. At the time, the inspection station I went to did visual inspections of the exhaust so I needed it to look factory. Its not like I can't afford the dp, I just never got around to it.
The Dejon piping fits perfectly. I don't have any fittment issues or rubbing on the hood at all.
My previous dyno numbers were with a tune you pretty much described. I was running 17* up top for timing. Maybe my car just dynos low :/
Right now I was just looking for 300+ WHP until the upgrades. Maybe I'll dial back boost just a tad. I got on it in 2nd today and it boosts 23-24 psi. 3rd I saw 25-27 depending on load. Car pulls like a raped ape.
satisfied
Oct 19, 2015 12:35 AM
Builttss
Oct 4, 2015 10:21 AM
jimbofug007
Oct 2, 2015 12:06 PM
roth
Sep 26, 2015 12:16 PM
Builttss
Sep 21, 2015 04:29 PM
