Just ordered a TF Dealer kit!
So 200 dollars worth having that better powerband? The only reason I went with Trifecta in the beginning is I was a little iffy with the warranty. Now that Vince teamed up with you I can hide the HP tune.
My personal opinion is yes. Take Cmillers car for a perfect example. He ran a best of 12.4 @ 1xx (I honestly forget the trap speed!), on the same setup with just changing to my tune he got down to a 12.14 @ 1xx. His most recent run was 12.16 @ 116 and that is on slicks LOL
Edit: When I ran Ryan's (glhs) TF tuned balt I was on 22psi and he had a 24psi tune on his car. While it was neck and neck (and honestly some good racing!) you could see how much longer I could stay in the same gear making power! On 24psi my car is a bit quicker still! Im supposed to be meeting up with him again, Im hoping we can get some runs in vs each other again
I trapped in at 116 on the k04 although being almost a second slower than cmiller (stock conti's for the SUCK)... and 122 on the 2871r... if you manage the dals well enough you can get the car to hold boost a bit better and drag the powerband out some.
I got picked on by a trifecta tuned 2.2 today.... It did not end well for him even with me barely going over 75% throttle
I used to be. With Nicks tunes I have picked up a whole 1-2mph in the 1/8th and trapped the same as before untill I got an intake, now with that I have been consistant 114-116 in the 1/4 and 92-95 in the 1/8th. I asked the track if the lights could be off, and they said that Norwalk is mandated to be within a certain NHRA spec so there not off he said. That was my first thought when I seen the slip lol.
Matt @ ZZP ran 11.997 @ 114.3. We are right there
Really depends on the track too. A person with the same tune that was on my car at a better track was hitting 12's no problem, I can't seem to break thru 13's on street tires at my track. My track is just awful tho LOL!
Last edited by BYT*SS*TURBO; Jun 9, 2010 at 07:55 AM. Reason: Automerged Doublepost
