K04+ Damaged, is there a work around?
Old Oct 8, 2011 | 07:42 PM
FF_ace's Avatar
Just bolt it up and be done with it its fine no need to try and fix
Old Oct 8, 2011 | 07:52 PM
09BlueBaltSS's Avatar
Originally Posted by Frogstofall
While it may be common, cracks only get worse, not better. Personally I'd try to have it welded.
Watch a small piece of weld come off and take out the turbine
Old Oct 8, 2011 | 09:24 PM
vahdyx's Avatar
yeah that would suck super big ass! I'm in a rock and a hard place it seems. Fix it, or slap it on? I'm struggling to make a decision.
Old Oct 8, 2011 | 09:29 PM
Omnigear's Avatar
Originally Posted by kingg5
lol @ shipping caused that.
^this , if its shipping then it would have a dent
it looks like a heat fracture
Old Oct 8, 2011 | 09:33 PM
BLAZIN07SS's Avatar
I'm too JDM for you
all the lnf k04's do this. it's no big deal
Old Oct 8, 2011 | 10:26 PM
gdubs's Avatar
I told you this was normal. I'll look for the tsb on it from gm
Old Oct 8, 2011 | 10:50 PM
BooSSted's Avatar
Send it back bro. If you're not happy with it, why would you keep it?
These things aren't difficult to find, so you can get another.
Old Oct 8, 2011 | 10:53 PM
MastaShaKe_88's Avatar
TX.SS.TC didnt even install it on his car >.< jus put it on your car, drive it for a lil bit an take it in under warrenty an see wat they say
Old Oct 8, 2011 | 10:54 PM
Dart_SI's Avatar
im just going to throw mine on. i really dont care if theres a small crack on it. im sure if everyone pulled their turbos anyway thered probably be a small crack on half of them.
Old Oct 8, 2011 | 11:28 PM
Fastgti69's Avatar
I think you can put it on, nothign should happen. i've seen this happen to evos and stuff too cause they have the twinschroll mani too. Shouldnt be a problem I've actually seen this happen on this forum too.
Old Oct 8, 2011 | 11:36 PM
  #36
FF_ace's Avatar
I have same crack on the turbo housing and my manifold mine look bigger than yours its nothing to sweat
Old Oct 9, 2011 | 12:46 AM
  #37
rivaladore's Avatar
X2..........that was most likely there before shipping
Old Oct 9, 2011 | 12:52 AM
  #38
rukkee's Avatar
#09-06-93-002: Turbocharger Housing Inlet Flange Cracks in Partition Wall - (May 27, 2009)
Subject: Turbocharger Housing Inlet Flange Cracks in Partition Wall
Models: 2008-2009 Chevrolet Cobalt SS, HHR SS
2007-2009 Pontiac Solstice GXP
2007-2009 Saturn SKY Redline
2007-2009 Opel GT
2007-2009 Daewoo G2X
All Equipped with Engine RPO LNF
Please Refer to GMVIS
Important: DO NOT replace the turbocharger assembly for this concern.
The purpose of this bulletin is to address concerns with turbocharger housing cracks in the inlet flange partition wall. Vehicles diagnosed with various driveability concerns or turbocharger DTCs P0299 or P0234 after inspection, are revealing cracks in the inlet flange partition wall of the turbocharger housing. Turbocharger assemblies are being replaced based on the discovery of these cracks.
The pictures below illustrate typical cracks found in the turbocharger housing.
This illustration shows the location of the cracks in the partition wall of the turbocharger inlet flange on the left (1) and on the right (2).
This illustration shows a close-up of the crack on the left side of the partition wall (1).
This illustration shows a close-up of the crack on the right side of the partition wall (2).
These cracks are not uncommon and are considered a normal condition and should NOT be a reason for replacing the turbocharger assembly. The cracks will not affect performance. If the vehicle exhibits driveability concerns or turbocharger DTCs P0299 or P0234 are set, refer to SI and follow the established diagnostics for correction of the customer concern.
Old Oct 9, 2011 | 04:48 AM
  #39
Fastgti69's Avatar
^^ thats awesome. Thanks
Old Oct 9, 2011 | 10:28 AM
  #40
HHRSSouth's Avatar
Originally Posted by Dart_SI
so i just checked my bnr gt28 and i have the same thing. must be common
Refer to post #14
Me and Brian@BNR even talked about the dividers being cracked 3 weeks ago when I rode down with a Alabama Cobalt SS/TC owner to buy one, his had a crack in the stock K04.
My Stock K04 off my HHR SS I traded in on a BNR 2871GT with only 10K miles on it had a crack, no big deal.
Old Oct 9, 2011 | 01:52 PM
  #41
vahdyx's Avatar
Well, I'll slap it on then! No worries!
Old Oct 9, 2011 | 02:26 PM
  #42
Frogstofall's Avatar
While I understand this crack is no big issue, please re-read your comment and ask yourself if it makes sense....
The crack is on the exhaust side big guy.
Old Oct 9, 2011 | 04:34 PM
  #43
rukkee's Avatar
NP ....Glad to help!
Old Oct 9, 2011 | 04:49 PM
  #44
BLAZIN07SS's Avatar
I'm too JDM for you
Might want to read your own comment again
Old Oct 9, 2011 | 04:58 PM
  #45
Chevycobaltss3's Avatar
Yeah bro. Theres no way shipping caused that crack. If it did there would be proff before the crack of it hitting somthing. That was there before.....get ure money back.....
Old Oct 9, 2011 | 05:00 PM
  #46
Even tho its a little crack. It can and will get larger with hot and cold. .. Once it cracks more the stress on the crack can cause it to break (peices or the whole damn thing.) dont install it spend ure money on somthing larger.. or better
Old Oct 9, 2011 | 05:03 PM
  #47
BLAZIN07SS's Avatar
I'm too JDM for you
James, all stock LNF turbo'd do this
Old Oct 9, 2011 | 05:09 PM
  #48
Lol i know this i know the tsb. ( ill explain more. .... The dealership that i work with for doing aftermarket tunes came to me and said he theres a tsb for this car and we arent replacing the turbo, what do you think)....??? I said the same thing i did here. Later on about a year or a little less that crack became a larger crack which also warped and it caused bad exaust flow. The reason the car came ba k to the dealer was because its turbo fluttered un any boost. Put a new ko4 on it and it was gone. I am more or less saying it can happen ( safety first).... theres prob some stuff that caused it as well egts getting to hot. But who knows lol..
Old Oct 9, 2011 | 05:36 PM
  #49
LittleRedRocketSS's Avatar
That's from the heat they do that
Old Oct 9, 2011 | 05:37 PM
  #50
cobaltssoverbooster's Avatar
thats a heat stress crack in the divider there is no real easy way of fixing that and mine has two in it and i just put it back on it will be ok. the fix requires heating the housing with an oven and while its glowing cherry hot then you weld it up.
