K04+ Damaged, is there a work around?
Old Oct 11, 2011 | 07:44 PM
  #101
HHRSSouth's Avatar
Originally Posted by vahdyx
I got fucked by TX.SS.TC or pwerks
They can't INSTALL the Turbo without serious modification. They have to weld a stud on and drill new bold holes. I'm pissed off.
Who's doing your install, putting studs in is not a serious modification.
If you wanted to you could use hardened bolts, lock washers and nuts to bolt the down pipe to the 02 housing.
Sounds like they are trying to rip you off to me.
Old Oct 11, 2011 | 08:02 PM
  #102
gdubs's Avatar
You can take the studs out of your stocker and use them. ITs what i had to do
Old Oct 11, 2011 | 08:19 PM
  #103
vahdyx's Avatar
Sorry guys I over reacted. I panicked but they did as you said. Weld tap new holes etc. Its going in now. I think everything will work out. At least I hope so.
All the holes were stripped.
Old Oct 11, 2011 | 08:33 PM
  #104
cobaltssoverbooster's Avatar
sucks bro that job only takes me about 4hrs to remove and replace on floor jack and stands...with emphasis on the about lol... sorry your having those hiccups i know u cant wait to have it running again. and the elbow is the most retarded part to remove and install.
i know how it feels im on the 4th turbo now......(1 ko4+ disaster, 1 journal failure, and 1 retarded factory tech loosing maf screws in the intake...*******....)
Old Oct 11, 2011 | 09:53 PM
  #105
gdubs's Avatar
4 hours? holy hell thats fast. I took me 6hrs spread over 2 days because i got too damn frustrated
Old Oct 11, 2011 | 10:24 PM
  #106
like i said im on number 4 ive had time to perfect the install hahaha on behalf of my hurting wallet
Old Oct 11, 2011 | 10:31 PM
  #107
gdubs's Avatar
I'd say so. And that the bolts are all nice and loose
Old Oct 11, 2011 | 11:04 PM
  #108
FasterIsBetter's Avatar
Glad you got it worked out. I'm sure it'll be fine.
I need to check for shaft play on my turbo. I'm sure its prob got a lil play and if so the balts going up for the winter and a turbo kit will be ordered a lil sooner than expected!
Old Oct 11, 2011 | 11:09 PM
  #109
Chevycobaltss3's Avatar
SO I SEE A Larger turbo to tune yay!!! Get some more power lol
Old Oct 11, 2011 | 11:33 PM
  #110
gdubs's Avatar
He is tuning with Trifecta
Old Oct 11, 2011 | 11:36 PM
  #111
I think he was talking about me, lol!
I'm prob goin with the s252 kit from zzp or the efr kit from pwerks
Old Oct 11, 2011 | 11:39 PM
  #112
gdubs's Avatar
the efr kits from pwerks look really solid. If I felt the car was worth it I would buy.
But the cobalt is done for me. Time to start learning about turbo supra
Old Oct 11, 2011 | 11:43 PM
  #113
I hear ya. I was wanting an e46 m3 to mod to begin with, but they get expensive fast where they aren't turboed from the factory and HorsePowerFreaks is just plain ridiculous anyways. It'll be one of those "When I graduate college..." things.
Old Oct 11, 2011 | 11:56 PM
  #114
Turbo supra hmm Want some more know how!!! LOL IVE OWNED gen 1s 2s and mk3 **** 4s.. i still own two celica supras that im building. Ive owned a few mk3s one was a 1jz swap with a single gt35rs And i tuned it as well with the build...
Old Oct 12, 2011 | 07:15 AM
  #115
vahdyx's Avatar
It's on and I drove home which was an hour away! I'm getting surge like crazy at partial throttle, not sure if it's my Forge BPV and it's yellow spring or if it's tuning since I'm still on my regular Trifecta Tune. I sent a series of logs to Vince, I believe he'll get back to me before the day's over.
As for the WOT pulls well, it's already noticeable for the better. I'll get dyno'd and all that good stuff too. I'd say it's a good mild increase. I'm happy with it unless this Surge can't get figured out.
I don't believe its not flutter, its has to be surge, happens on boosting building or before the bypass; before I let of throttle.
Old Oct 12, 2011 | 10:13 AM
  #116
gdubs's Avatar
It will go away when ur tune is dialed in
Old Oct 12, 2011 | 10:23 AM
  #117
Wangspeed's Avatar
Why the hell are you attempting a WOT pull before it's tuned? Ugg.
Old Oct 12, 2011 | 10:31 AM
  #118
vahdyx's Avatar
I'm tuned Trifecta, not stock, but it's dialed in for a K04 not K04+
And to answer your question Vince suggested I do WOT's mixed with various driving conditions. So I obliged. Just doing what I was told.
Old Oct 12, 2011 | 11:10 AM
  #119
rukkee's Avatar
I'd imagine Vince would have wanted that for data logging purposes ...... but only for datalogs I'm guessing.
Old Oct 12, 2011 | 05:50 PM
  #120
vahdyx's Avatar
Vince sent me his first revision and surge is barely present. It feels better and stuff, but there's crazy fluttering now. It's almost if my forge bypass valve's yellow spring is too much or too little for it. Not sure, I'll wait until he finishes dialing me in before I mess with the spring.
I have forge's spring kit so I may try green and if that doesn't work I'll try blue.
Old Oct 12, 2011 | 07:05 PM
  #121
HHRSSouth's Avatar
Is the fluttering only present when letting off the throttle?
Old Oct 18, 2011 | 08:24 AM
  #122
vahdyx's Avatar
What a ****ing nightmare. The turbo was put on last Tuesday and Thursday I noticed a leak. I thought it was coolant from Firestone doing a coolant drain/flush and fill. So I took it back to Firestone and they found out it was an oil leak. I told Vince about it and he thought it was just the oil feed line or drain line not being torqued right. So I called up the shop that installed it and they said bring it up. I couldn't bring it up until Yesterday.
Took it in and he said your (meaning mine) oil lines are dry, it's coming from the turbo itself. So he took off my charge pipe and there's oil everywhere. Inside my Bypass Valve, intercooler, etc.
So I had to get him to put back on my stock turbo.
Filed a paypal claim against TX.SS.TC because he sold me a used (carbon build up in exhaust side) and defective turbo. That's my theory anyway.
HHRSSouth, yes turns out the K04+ doesn't like the yellow forge spring. Fixed the flutter with the green spring, but the problem with the turbo didn't end there.
Old Oct 18, 2011 | 12:04 PM
  #123
HHRSSouth's Avatar
I hope you get your money back man.
So the oil seals were shot in the K04+?
How many miles did TX.SS have on it?
If the K04+ turbo has low miles I would have emailed works racing and ask them wtf, no way the seals should be gone yet.
Who knows you might have gotten a free rebuild out of it.
See you should have got a BNR 2871GT turbo, by the time you get done paying for all the stuff wrong you could have had a BOV, a flange added and been on your way.
Old Oct 18, 2011 | 12:12 PM
  #124
user 72239's Avatar
Damn dude, im sorry! that sucks to hear. Hope you get your money back. Was there any damage to your car other than the turbo?
Old Oct 18, 2011 | 12:13 PM
  #125
I say get ure money back save it and get a efr.... Better turbo and smarter move for the money
