Lash Adjusters?
Old Dec 4, 2011 | 08:56 PM
TheBoss8688's Avatar
Lash Adjusters?
Ok so I have been hearing a ticking more of a rapid squek ticking sound under load, also at idle you can here it but not squeking. It's not the direct injection noise either. But now the story...
I went to the dyno the other day, I'm bolted and tuned at 23psi. But anyway I get on dyno after someone with the same mods. He ran 325whp. I only got 300whp. I blame it on crappy gas but afterwards a few guys said about the squealing and ticking that I've been hearing.
What does everyone think it is? I was being told lash adjusters??Y
Old Dec 4, 2011 | 09:18 PM
Bump before bed
Old Dec 5, 2011 | 01:44 AM
seeyaass's Avatar
You talking about my car? Lol, there has been cases where people's lash adjusters were trashed and they didn't even know it. Only way to know for sure is to take the valve cover off and check it out bro!
Old Dec 5, 2011 | 02:09 AM
MastaShaKe_88's Avatar
bump, i wanna know.. sometimes i hear the dreaded clickin 2 an difference between dyno numbers could jus come down to the tune or car itself..
but about these lash adjusters...
Old Dec 5, 2011 | 07:33 AM
Yea your car bro. I just figured I would somewhere close but there has been something wrong with my car since day one so it kinda was expected. But still in for answers.
Old Dec 5, 2011 | 08:36 AM
FasterIsBetter's Avatar
Usually when they're going bad, your car has a subaru gurgle iirc.
Old Dec 5, 2011 | 10:00 AM
seeyaass's Avatar
Hmm.. Dam I would pop off your Valve cover and take a look! It takes like30 min!
Old Dec 5, 2011 | 10:36 AM
Yea. Going to. Never sounds like a Subaru but it just has that ticking and it's only getting louder.
Old Dec 5, 2011 | 10:37 AM
seeyaass's Avatar
I'd definitely check it out !!
Old Dec 5, 2011 | 10:43 AM
Since I really don't know what they look like, can someone throw a pic with them circles or help me someday with it?
Old Dec 5, 2011 | 11:18 AM
JacBlackSS/TC's Avatar
you will clearly see if something is wrong with them they sit on top of the valve springs right underneath the cams you won't even need to do anything besides taking the cover off to notice anything out of place
Old Dec 5, 2011 | 11:53 AM
seeyaass's Avatar
They look like bullets kinda, ovalish, trust me when you open the valve cover you will definitely notice if something is out of place!
Old Dec 5, 2011 | 12:08 PM
klloyd's Avatar
Funny you say subbie noise, when you first started the car to back onto the dyno we kinda heard it and just looked at each other ans said "subbie??". It wasn't as loud as a dead cylinder would be but it was noticeable, I would look into that.
Old Dec 5, 2011 | 12:41 PM
O ****. Should have said something. But yea I'm going to look into it. Ok well I'll update everyone. I might start to pull things apart tomorrow. My dad knows a lot about motors but mainly older cars but he can help. Thanks guys for giving me advice and helping.
Old Dec 5, 2011 | 01:02 PM
klloyd's Avatar
Didn't think anything of it because it wasn't real loud and it sounded like it went away.
Old Dec 5, 2011 | 01:03 PM
Should I go buy a new gasket for when I go to put back together?
Old Dec 5, 2011 | 01:51 PM
Oh so I'm thinking it's just the start of an issue then
Old Dec 5, 2011 | 02:44 PM
ATLsilverSS's Avatar
you can reuse the valve cover gasket as long as you don't damage it. its just a rubber seal
Old Dec 5, 2011 | 11:02 PM
chitala383's Avatar
This may be my problem. I have a fast ticking noise and a subie type gurgle as well. How many lash adjusters are there?
Old Dec 5, 2011 | 11:40 PM
16, its $150 for a set from zzp and you might as well get springs/retainers ($290) too to solve the issue for good. Valve float from increased boost and a raised rev limiter is believed to cause the issue and is cured with springs.
Old Dec 5, 2011 | 11:44 PM
chitala383's Avatar
I'm gonna pull my valve cover on Thursday hopefully and check everything out. Hopefully that's the only problem.
Old Dec 5, 2011 | 11:54 PM
chitala383's Avatar
Are there any aftermarket lash adjusters? Bc the ones from zzp are oem. So my theory is that if i broke the original ones I'll break replacements as well unless they're more durable. Also, do i need to retune for the 82# valve springs? Or does it not make a difference? I've had this car for 3.5 years but I'm still kind of a noob at this ****. Haha
Old Dec 6, 2011 | 02:35 PM
so OP, did you ever go check under your Valve cover? how'd it look?? any pics???
Old Dec 6, 2011 | 02:47 PM
Pretty sure oem lash adjusters is what zzp uses. I dont believe there are any other options.
Old Dec 10, 2011 | 08:48 AM
Well my dealer is taking a look. They help me out even with performance so hopefully they take care of it. Still not sure if that's the issue
