Lash Adjusters?
Old Dec 12, 2011 | 11:10 PM
  #51
FasterIsBetter's Avatar
Originally Posted by seeyaass
just wondering why dont they want to pull the valvecover?
Its GM. Anymore if theres no noticeable noise during idle and normal driving or any CELs they just don't care.
Old Dec 13, 2011 | 10:18 PM
  #52
TheBoss8688's Avatar
Got car back today, they listened and heard a ticking also, but they replaced a cover over the fuel pump that supposedly had a bulletin because of rattling noise. So bullshit but I'm keeping records and will be pulling cable cover off during weekend. Maybe tomorrow if I got time
Old Dec 15, 2011 | 03:55 AM
  #53
Knightwolf's Avatar
Haha.. at least they called you and replaced that part! The dealer that told me that same thing, I told them to go ahead and order it and call me when they're ready(2 weeks shipping from USA), and I'd bring the car in to get it done. Never called, never installed... nice customer service GM! Lets just forget about even the bullshit that we told you would fix your problem and pretend the owners don't even exist!
Lmk your update when you find out dude... still curious.
Old Dec 15, 2011 | 11:21 AM
  #54
Of course. Am still thinking Saturday or Sunday. Ripping into it then.
Old Dec 15, 2011 | 03:43 PM
  #55
SSlobalt's Avatar
If you don't have anything under the valve cover that's an issue and you have a ticking under boost, it's just the wastegate flapper rivet. Nothing to worry about.
Old Dec 17, 2011 | 03:39 PM
  #56
Ok will posts pics later but 2 broken rockers and one lash adjuster laying around and the other one was cracked
Old Dec 17, 2011 | 08:32 PM
  #57
seeyaass's Avatar
Wow look at that man there ya go!
Old Dec 17, 2011 | 08:44 PM
  #58
Yup. Back 2 GM again
Old Dec 17, 2011 | 08:54 PM
  #59
Yea, lets see pics.
Old Dec 17, 2011 | 10:13 PM
  #60
I really don't know how to post or have the imageshack or anything to post. Can I send pics to someone or is it easy to make profile on one of those sites
Old Dec 17, 2011 | 10:36 PM
  #61
seeyaass's Avatar
Use photobucket, just make an account lol
Old Dec 17, 2011 | 11:32 PM
  #62
wow how to make smaller? lol
Last edited by TheBoss8688; Dec 17, 2011 at 11:32 PM. Reason: Automerged Doublepost
Old Dec 18, 2011 | 01:36 AM
  #63
Amazing that you didn't hardly hear the subaru tone with your lash adjusters/rockers like that.
Old Dec 18, 2011 | 02:39 AM
  #64
Mike_peperni's Avatar
Sound like you over reved your lnf!
If the dealer dont fix it under warranty i have some brand new lash adjusters, just PM me if you need any.
Old Dec 18, 2011 | 09:25 AM
  #65
the thing is i dont remember ever hitting rev limiter. I always shift early. Might have though. Damn but hopefully it will be fully covered.
Old Dec 19, 2011 | 05:45 PM
  #66
BlackSS185's Avatar
i told ya so
Old Dec 19, 2011 | 08:13 PM
  #67
Knightwolf's Avatar
You don't have to over-rev to have this happen, but if you did, it will happen much, much sooner. Increased boost also causes this. Factory springs aren't strong enough to support high boost at high rpms and thereinlies the problem. ZZP springs or head will fix it. That's all there is to it, or run low boost at high rpms, or a mild tune.
Old Dec 20, 2011 | 11:20 AM
  #68
Looking into upgrades. But probably going to lighter tune and be happy. Work on exterior
Old Dec 21, 2011 | 11:51 AM
  #69
Looks like I'll be taking care of this one myself. But is there any special tools I need for doing this?
Old Dec 21, 2011 | 05:02 PM
  #70
Just a 32mm socket. The same one used to pull your oil cap off. You will have to pull the timing chain tensioner on the back of the motor. Then pull the caps on the camshaft and raise it very carefully. Also notice the numbered caps and the arrows pointing towards the gear end of the camshaft. You have to put those back in order and pointing the right direction or you can scar your cam and those caps. With the ability to lift the camshaft up you should be able to easily place the rockers. DO NOT mess with the timing chain. Don't try to move it off of the gears. When you get your tensioner back in after you have bolted down the cam, take a wrench(7/8 seemed to fit well) and spin the camshaft on the notched hex part behind the gear to pull out any slack between the two, only do this after the tensioner is in or it could jump timing and possibly bend a valve. Torque specs on the caps are 89inch/lbs. I just snugged them up to a reasonable amount. You may get a 3/8 drive torque wrench if you want to do this.
Old Dec 21, 2011 | 05:38 PM
  #71
You dont need to remove the timing chain tensionner, what i did is just loosen the bolts on the caps that hold what keep the cams in place, go evenly, and slowly. Dont remove them, just loosen. Just enought so you can remove or add a rockers., i used a magnet to remove the lash adjusters.
This way no need to mess with the timing chain etc...
Retight to the right spec like FasterIsBetter posted and it should be good, at least i had no problem since.
I have 8 lash adjusters left, brand new, if you need any my offer still stand, 5$ each+shipping.
Old Dec 21, 2011 | 06:12 PM
  #72
soundjunky's Avatar
Originally Posted by Knightwolf
I was told this at one point also.. pull the bloody valve cover dude. I've had broken lash adjusters and rockers wedged in my head twice. It's all cured now with a ZZP stage 1 head, and the lash adjusters aren't the problem, it's the weak factory springs being pushed out at high rpms with increased boost causing them to pop the rockers. ZZP springs will cure it, or if it's too costly as was my case, just get the ZZP head kit for the same price as Gm's factory crap.
If it sounds like a Subie, you definately have either a broken lash adjuster, or a rocker arm sittin around in ur valve cover somewhere. If u throw another one, it will become more noticeable, have way less power, and then finally, start to throw misfire codes. I purposely threw the 2nd one in order to get GM to look at the bloody car since nobody would touch it by going from what I had said. They will only pop the cover if you have a CEL, which unfortunately, isn't going to happen since this is a mechanical issue that won't throw a CEL until it becomes severe. And, by that time, you will most likely need more work done than what they're willing to do under warranty, which was also my case. It broke again a month later without ever going over 6000 rpm.
I warn you now, don't trust GM techs, this site has more information than 99% of those guys have on our cars. I got lucky and found a good mechanic at one of my local GM dealers who actually listened to my concerns, and did what I asked, which was to pull the cover and LOOK. Everything's fixed now, and I'm happy with that particular GM dealership, whereas the rest in my city can jump on a washing machine with their bare ass and rotate on the spin cycle. He fixed my car with the parts I supplied and has done a wonderful job. Couldn't be happier, but he didn't put on my charge pipes tight enough and blew them off last night lol. I fixed that up myself :P
One other thing, you won't be able to hear any difference in the engine bay from having one thrown off. It's not actually contacting with the cam, so it sounds normal.
THANK YOU FOR POSTING THIS
I had four lash adjusters & rockers grenade on me very late this past winter...
I noticed an oil leak two weeks ago saturday, and stopped riving it...
brought it into the dealer, and it turns out one of my rockers came off...
I see a valve spring retainer is nearly popped out too...
so springs are the culprit huh....
dude! that's awesome!!
I hope you have warranty!
Old Dec 21, 2011 | 06:18 PM
  #73
I had a rocker break on left exhaust side valve on cylinder 1 in that corner(Its a PITA to get anything in and out of there. That's why I had to lift the cam up like I did, lol.
Good Luck OP!!
Old Dec 21, 2011 | 10:54 PM
  #74
Good Luck OP!!
Yeah i agree it was still tricky to remove them hehe, the magnet was useful though
Took like 15 minutes to loosen the caps, change the lash and rocker and retight the caps.
Getting everything out of the way , especially removing the braided line from the turbo was the worst part of the repair for me, that braided line was really tight in the turbo, without much room to work near it...
Old Dec 23, 2011 | 03:57 PM
  #75
well im now waiting till tuesday to talk to a GM rep about my options.
