LE5 throttle body on LNF engine?
Old Feb 26, 2011 | 05:30 PM
SKY888's Avatar
Anybody tried opening up the intake manifold and plugging LE5 on their LNF engine?
was planning to go with straight 3" IC pipings, and 3" ic inlet and outlet.....and using LE5 TB so there'll be no bottleneck.
just wondering if somebody already did it..........and if there are any issues that arised..
Old Feb 26, 2011 | 06:21 PM
silverbullet08's Avatar
I know there are people running larger throttle bodies but im not sure what they used... i havnt compared a LE5 TB to ours.. wonder if it will bolt up? The last LE5 Tb i saw was fairly small though.. not sure if it will net us any gains.
Old Feb 26, 2011 | 06:22 PM
Iam Broke's Avatar
BYT knows something, he hinted of a way to remove the throttle lag, might be this. IDK.
Let us know how it goes.
Old Feb 26, 2011 | 06:41 PM
cmiller8006's Avatar
You can use a le5 throttle body, there is one that has the same plug in as the lnf. There are some people that have done it and they picked up about 10whp, I dont remember if that was on a stock turbo or big turbo tho.
Old Feb 26, 2011 | 07:11 PM
SKY888's Avatar
gmtech opened his intake manifold to install LE5 TB, I just found out today.
he has to modify the DALs and MALTs and torque tables......
Old Feb 26, 2011 | 09:40 PM
Gunney_07's Avatar
zzp had tried this once and said it took a bit of tuning to get it right... something about the ecm has been designed around calculated surface area of the stock throttle body... i cant remember specifics.
Old Feb 26, 2011 | 09:42 PM
Gunney_07's Avatar
https://www.cobaltss.net/forums/2-0l...esting-171566/
Old Feb 27, 2011 | 01:06 AM
Matt M's Avatar
What we found was that if the ECM is not far from stock, it will compensate for the pressure drop change and gains are hard to come by. On the other hand, if the desired air loads are beyond an achieveable threshold, there are gains to be had by increasing the throttle plate diameter with the stock turbo.
On our S252 turbo swap, we picked up 8whp when I tried the LE5 TB. Unfortunately, throttle control for daily driving was too touchy so I went back to the stock TB. I imagine you could lower the DALs at low load to slow the throttle rate down some.
Old Feb 27, 2011 | 02:13 AM
gmtech16450yz
Guest
Posts: n/a
"On our S252 turbo swap, we picked up 8whp when I tried the LE5 TB. Unfortunately, throttle control for daily driving was too touchy so I went back to the stock TB. I imagine you could lower the DALs at low load to slow the throttle rate down some."
Bummer you had to give up 8hp because you couldn't figure out how to smooth throttle response.
(Oops, did I say that out loud? Oh well.)
Old Feb 27, 2011 | 02:20 AM
AyrtonSenna's Avatar
Would you suggest, on an LNF with a turbo kit like mine, to get the stock TB ported (like Nick will do on mine) or to just get the LE5 TB?
Old Feb 27, 2011 | 02:38 AM
BooSSted's Avatar
Giving up 8 when you've got over 500 (in a street car) for the sake of drivability seems quite logical to me.....
Old Feb 27, 2011 | 03:43 PM
Matt M's Avatar
I'm not sure what you are saying there. I didn't make any attempt to adjust the throttle response at that time. The experiment was to see if the TB would work as a simple bolt-on. In case you hadn't noticed, people throw fits when we sell a part with our tune required.
On the other hand, when someone else gets within 80 whp as us, the 8whp I left on the table might matter. lol.
Old Feb 27, 2011 | 04:19 PM
Gixxercobaltdriver's Avatar
Well hopefully you guys figure it out. Thanks for everyone who tries new **** like this.. was wondering this same thing today.. I will keep posted on this.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
