Less boost?
Old Sep 7, 2010 | 10:00 PM
Godly's Avatar
Less boost?
Well guys, I have my car tuned at 24 PSI, Had Mongorat do it a while back, sadly i've had a boost leak for a while, but I fixed that a week or so ago by putting on my charge pipes.
My 24 PSI tune is also including meth, but it hasn't been hooked up because I didn't have enough hose for the way I was running it to make sure it would never hit the ground, well I hooked it up this evening finally and now I only make 22 PSI instead of 24?
Is that right? i'm thinking it is, but im not 100%. Thanks in advance.
Old Sep 7, 2010 | 10:16 PM
Godly's Avatar
BUmp
Old Sep 7, 2010 | 10:58 PM
Godly's Avatar
? bump for info?
Old Sep 7, 2010 | 11:11 PM
peachpuff's Avatar
The ecm has a specific load setting in it and it'll run as much boost or as little to hit that number, so your boost numbers will vary from time to time based on outside conditions.
Old Sep 7, 2010 | 11:26 PM
tomj77's Avatar
ur talking learn down? if he is tuned to 24psi, it should boost to 24 psi no matter what, this isnt gm tune here.
Old Sep 7, 2010 | 11:55 PM
JPizzle's Avatar
Yea, I would think that if you had an aftermarket tune you should be boosting the same...... Hmmm.
Old Sep 8, 2010 | 12:02 AM
ecot3c inside's Avatar
data log it?
Old Sep 8, 2010 | 12:12 AM
Wangspeed's Avatar
You have no idea how this ECU works.
Old Sep 8, 2010 | 12:46 AM
CurrentlyPissed's Avatar
Yes, the ECM works on what is called DAL #s (Dynamic Air Loads) all it has to do is acheive those cells. With whatever boost it takes, 24, or 21. It's not just a smash 24 psi all the time.
This is why you (correct me if I am wrong wang) see less boost in the cold air since it's achieving more CFM per lb since the air is more dense.
Old Sep 8, 2010 | 03:27 AM
jrzdude's Avatar
ECM may be pulling timing and boost due to your meth not being hooked up. If its tuned for meth, im assuming the timing was advanced a bunch, so it may be a failsafe not letting it boost that high due to the lack of "octane". Could be going in the wrong direction here...
Old Sep 8, 2010 | 08:05 AM
Iam Broke's Avatar
If your tune maxed out the DAL table in cooler weather and now the ambients are warmer, it isn't going to make 24 psi with thinner air.
At any rate, you need to get datalogged & fine tuned for the meth.
Old Sep 8, 2010 | 08:12 AM
Godly's Avatar
Welp guess I need to order the trifecta cable then
Old Sep 8, 2010 | 08:50 AM
mongorat427's Avatar
The cable comes in handy plus you allready paid for your tune. Ill be up at the Festival of Speed Saturday 9 to 5. Going up for some track time with an instructor.
Festival of Speed
Date : 09/11/2010
Time : 9:00 AM - 5:00 PM
Description : A plethora of events including Gymkhana, Autocross, Time Trials, Show & Shine and much more!
http://maps.google.com/maps?saddr=I+...733.9347&hl=en
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
