LNF Clutch
LNF Clutch
Who makes a good clutch for the LNF? I ask because I already experienced quite a bit of slip when I took it to the strip, in first gear, the tires hooked on the VHT, but the motor started to rev with my foot all the way off the clutch. Just wondering...
Get a Spec stage 3+. It will handle up to 500 ft-lbs torque and is a full disc clutch so it will have more holding area and a smoother engagement than a puck style clutch. You should not be slipping at all unless you are tuned.
patooyee
Oct 1, 2015 01:07 PM
