LNF Compression Test
Old Sep 12, 2012 | 01:16 AM
LNFnewb's Avatar
I suspect my car is having an issue with compression (possibly a bad ring). I plan on doing a compression test tomorrow. Already got the tool, but now my question is what is the proper procedure to do it with the LNF?
I know I need to pull the fuse for the fuel pump and let it run until it dies, but what do I need to disconnect regarding the ignition/coils, should I do the test while the motor is cold, or let it get to operating temp first, and lastly should I pull all the plugs while testing the cylinders or only pull the plug of the cylinder I'm checking?
Old Sep 12, 2012 | 04:23 AM
vahdyx's Avatar
I'm interested as well
Old Sep 12, 2012 | 05:49 AM
Iam Broke's Avatar
Unplug all the coil packs & pull all 4 plugs. Hold the throttle open and crank it until you hear 5 or so compression strokes on the cyl you are testing or until the gauge quits rising. If it doesn't peak in 5 strokes you have issues anyway.
Should read 150-165 if they are in good shape.
Old Sep 12, 2012 | 08:25 AM
user 72239's Avatar
ours will read lower mike. Mine was consistently 130 across the board but the above way is the way I did it. My battery died on the last piston though
Old Sep 12, 2012 | 11:22 AM
vahdyx's Avatar
Hopefully mine doesn't die
Cool, thanks dude. I bet I would have freaked out if I gotten a lower thing and you didn't tell me haha.
"Oh no! All 4 of my pistons are fucked"
Old Sep 12, 2012 | 11:28 AM
TurboTechRacing's Avatar
Dont drive it any more than you must with a possible bad piston, you could take the risk of scoring the cylinder/sleeve, requiring new sleeves or a block. Wiseco makes nice pistons if you find you need a new set.
Old Sep 12, 2012 | 11:45 AM
AARON-SS-TC's Avatar
damn, how could you have a bad piston already? thats not very common on here, at least from my observation.
Old Sep 12, 2012 | 12:05 PM
LNFnewb's Avatar
Recently did an oil change on my car, smelled fuel from the oil(I have no sense of smell almost so when I smell anything it always catches my attention). So I figured I'd see if I'm getting blow by. I know of a few people who have had issues with blow by actually. Just trying to see if I'm over thinking it or if there actually is a problem.
Old Sep 12, 2012 | 02:24 PM
understandable, i am the same way
Old Sep 12, 2012 | 03:27 PM
CudaJoe's Avatar
hmmm my car always smells like gas when its running at idle. I dont think I could locate an issue via smell with my car.
Old Sep 12, 2012 | 06:03 PM
wol-shiver's Avatar
Just t o confirm,
this needs to be done?
I need to pull the fuse for the fuel pump and let it run until it dies?
Old Sep 12, 2012 | 09:25 PM
user 72239's Avatar
my oil smells like it has gas in it too. but my compression test was good. Turbo cars have some natural blowby as the piston rings arent a 100% seal.
Old Sep 13, 2012 | 03:17 PM
rukkee's Avatar
My oil smells like gas sometimes too..... I just figured it was somewhat normal because it's done it since new ...... still runs great .
Old Sep 13, 2012 | 03:38 PM
umrdyldo's Avatar
I have never smelled it but my oil sample that i previously did had a larger than average amount of fuel in it. I think it may be the nature of the beast.
That was 30k miles ago.
Old Sep 13, 2012 | 04:19 PM
SeanEE89's Avatar
Did a compression test on mine after seeing this 150psi in all 4
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Trav3480
Oct 1, 2015 08:17 PM
patooyee
Oct 1, 2015 01:07 PM
