LNF head flow benched
Old Apr 4, 2012 | 10:02 PM
FF_ace's Avatar
put my stock LNF head on the flow bench heres the numbers. looking to get it ported and will see what gains it makes
Old Apr 5, 2012 | 12:09 AM
ATLsilverSS's Avatar
In english lol
Old Apr 5, 2012 | 11:08 AM
gone_in_10_sec's Avatar
Here is a good book on understanding how the flow bench works and how to read the numbers and what they mean..
Superflow - Flowbench 110 - Instructions
Old Apr 5, 2012 | 11:19 AM
Staged07SS's Avatar
Administrator
Administrator
This could become a very good thread!
Nice way of running a before/after comparrison.
I'm looking forward to your results.
Old Apr 6, 2012 | 06:27 AM
oldskool's Avatar
Thanks for posting this - in for results!
Old Apr 6, 2012 | 12:54 PM
Wangspeed's Avatar
Hope you have someone familiar with DI do it, because it would be easy to mess up the head.
Old Apr 6, 2012 | 01:36 PM
noorj's Avatar
How so? I've flow bench a few small engine heads and were much more careful with the bench itself rather than the head
Old Apr 6, 2012 | 01:51 PM
Gremlin85's Avatar
^This.
ZZP is the only one that has actually ported an LNF head to make any kind of gain. The direct injection makes a huge difference in how the air needs to be introduced into the cylinder matched with proper piston design ,injector angle, spark plug etc etc etc.
Have fun with it but don't think that because you got better flow numbers on a bench that you are actually going to make power. Chances are is that you'll hurt the motor more than help it.
Old Apr 6, 2012 | 02:18 PM
09BlueBaltSS's Avatar
Now buy a ZZP head and strap it down.
Old Apr 6, 2012 | 04:54 PM
cobaltssoverbooster's Avatar
do not touch the ski ramp section on the floor of the runner right before the valve unless you want a tuning nightmare that results in no torque. i know because i have that done already.
i know someone will say proof so heres my ports:
factory intake chamber side
modified chamber side
modified manifold side
Old Apr 6, 2012 | 11:40 PM
Zooomer's Avatar
Supporting Vendor
LNF intake flow is horrible. WAY less than LSJ or NA heads.
The flow issue is with the sharp break as pictured by another user. Just round that off and gains are massive...on the flow bench. bolt it back on the car and HP is GONE.
Old Apr 7, 2012 | 01:44 AM
Knightwolf's Avatar
Haha ZZP already played with this and found out the hard way, but somehow perfected it :P I wish you luck sir :P
Old Sep 13, 2012 | 12:23 PM
FF_ace's Avatar
well found a guy that does a lot of lsx work. hes done a lot of research looking into the di motors will had my ported and polished head, intake manifold, and tb by the end of the month
Old Sep 14, 2012 | 11:28 AM
noorj's Avatar
Good luck, hope it works out for you.
Old Sep 14, 2012 | 03:31 PM
SSlobalt's Avatar
This is the part of modifying cars that I will never understand. It sounds like a huge waste of money for minimal gain. Strap a bigger turbo on it, put some valve springs in it, make more power. Cheap and easy.
Old Sep 14, 2012 | 04:03 PM
FF_ace's Avatar
well i already have a fully built motor with zzp valve springs/cams, full bolt ons, ccs3 26 psi tune on e47 and methanol injection. custom turbo kit with a pte dbb 5857 billet wheel turbo so no its not a waste of money because ive done everything else i can this is the last piece
Old Sep 14, 2012 | 04:04 PM
SSlobalt's Avatar
Ah. You have old numbers on your sig, then. You're already past the point where I even understand taking a front-wheel drive.
Old Sep 14, 2012 | 04:07 PM
FF_ace's Avatar
ya my numbers and times are on my stock turbo setup if i knew how to make a sig i would . theres a few guys that have a lot more power than me on a fwd car and the are doing fine.
Old Sep 14, 2012 | 04:18 PM
Kahless's Avatar
define fine. these are the heads i was going to get for my 65 merc. you have to have the tune and cams to take advantage of the airflow gains. but like he said its easy to screw up and it seems people have tried.http://www.totalengineairflow.com/pr...ted-high-port/
Old Sep 17, 2012 | 12:51 PM
do you have a picture of the stock head without the porting? especially with a view of the intake & exhaust side ports looking through to the chamber? [the opposite of the first picture]
Old Sep 17, 2012 | 06:01 PM
FasterIsBetter's Avatar
Yeah, its not like you have much torque steer with a larger turbo due to the slower spool. You just spin a lot, lol.
Old Sep 17, 2012 | 06:04 PM
I'm having a spare intake mani tb opening bored out a half inch right now. Will def need tuned for it but should see quite a gain with a larger turbo. Going to be running the 3.6DI throttle body. I'm estimating with the ported intake mani somewhere around 10-20 crank hp.
Old Sep 18, 2012 | 05:28 PM
Stamina's Avatar
sub'd
Old Sep 18, 2012 | 06:00 PM
FF_ace's Avatar
Ill try and post some pics of port work so far
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Trav3480
Oct 1, 2015 08:17 PM
patooyee
Oct 1, 2015 01:07 PM
