LNF and LK9 intake manifolds
The only thing that bolts to an lnf is the lnf/ldk manifold or lnf sheet metal intakes. However there are aome slight differences to the ldk
You cannot bolt a lnf manifold up to anything other then an lnf head.
Post correct. Thanks for the correction tom.
Thanks. Forgot about that. But even then unless your on 3 bars its not the same. So for a direct swap no.
As far as throttlebodies go i do not think so. However theres a version of the 2.4 le5 throttlebody thats plug and play for the lnf
It doesnt work with the stock sensors, with 3bar u need to drill and tap a diff bolt hold cause no they dont fit 100%, thats only issue though
They are interchangeable. You need to drill and tap a hole for the map sensor. Forgot all about that. No point in changing over unless you want a new manifold. Im going to building some sheet metal ones soon
Yup. Its the exact same manifold except the map sensor bolt hole is on the wrong side so u need to make a new one. Lnf mani has 2 bolt holes, ldk only one, but the place is there for the second
