LNF o2 sensor removal
Old Apr 3, 2009 | 02:04 PM
rm.lydon08's Avatar
I need help, I can't egt the o2 sensor out. Im trying to change my downpipe, I have 2 hours till work, any tips?
Old Apr 3, 2009 | 02:06 PM
Terminator2's Avatar
Do you not have the correct size wrench? Is it stuck?
rm.lydon08's Avatar
it won't budge, and I don't know where to un clip it
Old Apr 3, 2009 | 02:08 PM
It unclips behind the motor near the black crossmember under there. Penetrating oil should help you unscrew it, Mine was not that tight.
Old Apr 3, 2009 | 02:10 PM
umrdyldo's Avatar
I had to unclip mine on the old Cobalt I had. then took the whole DP out and put it in a vice
Old Apr 3, 2009 | 02:12 PM
tomgillotti's Avatar
Hey.. not sure where you ordered the DP from, but if it was Clear Image, they are always very helpful.. just give them a call and they could probably walk you through it.. GL
Old Apr 3, 2009 | 02:35 PM
krispy's Avatar
Do you have a O2 sensor socket? They really help in taking them off.
Old Apr 3, 2009 | 02:36 PM
Dustinss's Avatar
Did you let the exhaust cool down first?
Old Apr 3, 2009 | 07:07 PM
buellfooll's Avatar
Old Apr 3, 2009 | 08:16 PM
glhs379's Avatar
use a small pipe wrench, works everytime!
Old Apr 4, 2009 | 04:36 AM
IsItFast?'s Avatar
A judicious application of propane and a spark works well.. (aka heat around the o2 sensor with a torch, it will come right out)
Old Apr 5, 2009 | 10:18 PM
BIGTAG's Avatar
just man up a heeve that sombitch
Old Apr 5, 2009 | 10:43 PM
Turbo'dSS's Avatar
i used an adjustable wrench and mine came right out. had to unclip it though. just follow the wires.
Old Apr 6, 2009 | 01:09 PM
krispy's Avatar
Oh yea, make sure you re-apply anti-seize before putting it back in. Anything that screws into an exhaust should have anti-seize on the threads.
Old Apr 6, 2009 | 01:10 PM
Dustinss's Avatar
Not really
Old Apr 6, 2009 | 01:17 PM
Originally Posted by Dustinss
Not really
Why not? All that heat equals a lot of oxidation over time which will cause seizing especially if you live near saltwater or up north. Just dont get the antiseize on the O2 sensor itself just the threads.
Old Apr 6, 2009 | 01:23 PM
umrdyldo's Avatar
Originally Posted by Terminator2
Why not? All that heat equals a lot of oxidation over time which will cause seizing especially if you live near saltwater or up north. Just dont get the antiseize on the O2 sensor itself jsut the threads.
agreed. Can't hurt anything. Only helps you down the road.
Old Apr 6, 2009 | 02:24 PM
krispy's Avatar
Not really
Thats how it goes when you actually are trying to make things so that they are servicable. All the heat and moisture in an exhaust will rust everything eventually, anti-seize will make it to its more of a breaker bar job, not a torch/breaker bar/hammer job.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
jmelton327
Sep 26, 2015 10:04 PM
