LNF Throttle Body Swap Testing
In our quest for more power out of our 08 SS/T, we decided to try swapping to a larger TB. I didn't expect huge gains based on past experience with forced induction TB sizing, but I was hoping to see a 2-3 HP gain. The TB we chose for the upgrade was the 2.4 LE5 TB. I don't remember the exact sizes right now, but the LE5 TB is 4 or 5 mm larger than the LNF TB. Here is a pic for comparison:
http://sites.commercecreators.com/fo.../lnfle5tbs.bmp We machined an inatke to match the LE5 TB. http://sites.commercecreators.com/fo...swapintake.bmp Current setup on my SS/T includes: ZZP airbox mod on factory airbox AEM intake tube Stock turbo ZZP upper charge tube Stock intercooler and lower charge tube ZZP ported head ZZP offroad downpipe ZZP custom catback ZZP tune When dyno testing new parts on the LNF, we use an external boost controller to keep the PCM from altering the boost level and skewing the results. After several dyno pulls in the 335-336 whp range using the stock TB, I swapped in the new intake manifold and LE5 TB. The swap was very easy and the car idles smooth and has throttle response not much different than before. Unfortunately, the dyno results were not at all what I was expecting. After 3 pulls, the best number it put down was 323 whp. There are no vacuum/boost leaks. The MAF readings decreased in correlation to the HP loss. Here is the graph: http://sites.commercecreators.com/fo.../lnftbtest.bmp While I realize that over-sizing the TB does not offer HP gains in many situations, this is the first time that I have witnessed a significant loss in HP from a swap of this type. I am going to look into this a little further tomorrow. I'm hoping that for some odd reason, the 2.4 TB only opens half way with the same signal that opens the LNF TB 100%. However, I'm not holding my breath, as that seems like a long-shot. |
Maybe try swapping over everything from the LNF TB to the 2.4 TB?
Interesting idea. Definitely staying tuned for more info...
I would imagine more airflow would be a good thing, lol. Hope it gets panned out. Have you thought of trying this on the big turbo balt? |
400 tq?
Originally Posted by Mazdaboi318
(Post 3879591)
400 tq?
VERY impressive man... wow. i had no idea....
Originally Posted by Matt M
(Post 3879636)
The highest it put down so far was 411 ft lbs.:)
Wait... you are pushing 411 ft lbs from the stock turbo?!?!!?!!??!?!?
Holy smokes. |
I appreciate what you guys are doing Matt btw....
(Post 3880340)
x3!!!!!!!!!!!
tq falls off rediculously fast.
I have never seen a dynograph where peak HP is made at like...early as fack :lol:
And that is the tune making it spike up and fall so much |
looks like the torque is just a boost spike. I am going to go ahead and assume the maps are clamped and your spiking the turbo in to the upper 20's to get that torque. yes/no?
Originally Posted by mkriebs
(Post 3880117)
Holy smokes. all that done to mine is 3" custom intake, 2.5"custom hardened charge pipes hot/cold sides, BIGGER intercooler,3" custom downpipe, solid trans mounts, solid upper motor mount. Custom tune 23lbs of boost. |
(Post 3878454)
Originally Posted by OneCOLDBIZL272
(Post 3880692)
yeah it possible my 09ss/tc is 316hp394.6lbs tqr
Originally Posted by steddy2112
(Post 3880494)
And that is the tune making it spike up and fall so much Having said that, yes boost is over 25psi at the start of the pull, and down to about 17 by the end of the pull.
Originally Posted by Terminator2
(Post 3880786)
larger TB will never work properly because the ECM calculates the pressure drop over the diameter of the TB. Changing the diameter skews the readings the ECM gets and it looses power as you all saw.
how hard was it to get the head off for porting lol
i might have to drive to MI to get my head ported :)
(Post 3880494)
(Post 3881705)
Most people think that tunes are making the boost spike on these cars, which is not what happens. The actual problem is that exhaust pressures get too high for the wastegate to control boost consistently. Exhaust just pushes past the gate and boost falls off. If you roll up to 5000 RPM real slow and then go WOT, the peak HP number is 10-15 WHP higher.
Having said that, yes boost is over 25psi at the start of the pull, and down to about 17 by the end of the pull. The PCM does in fact compare the pressure readings, but what are you claiming to be the reason for the HP loss? Are you saying that the ECM closes the throttle until the pressure drop is where it would like? And if so, why would there be a loss of power instead of the same power?
Originally Posted by revhigh18
(Post 3881787)
THAT WAS NOT THE STOCK TURBO! CHeck their other thread people... this turbo runs out of breath well before 400ft/lbs
Originally Posted by 1badBlueberrySC
(Post 3882536)
Current setup on my SS/T includes: ZZP airbox mod on factory airbox AEM intake tube Stock turbo ZZP upper charge tube Stock intercooler and lower charge tube ZZP ported head ZZP offroad downpipe ZZP custom catback ZZP tune |
THey are yankin' someone's ding dong... in their other thread...
411ft/lbs was on an upgraded turbo! |
Thats what I thought... but it also turned much more HP than 323 to the wheels. I asked in my first post, and didnt get an answer.
The turbo cannot support 411ft/lbs...
Just ask Terminator pretty much has max'd it out... at 350whp and 375wtq I smell somethin....... |
