This is WONDERFUL
wow ..........
Originally Posted by 1badBlueberrySC
(Post 3882536)
THAT WAS NOT THE STOCK TURBO! CHeck their other thread people... this turbo runs out of breath well before 400ft/lbs
I didn't spike mine that high but it was seeing 380wtq with clamps. I had no problems on the dyno but once at the track the car would throw an underboost code. My map sensor took a sh*t with those clamps on so not sure if it was them or just junk gm sensors
Originally Posted by Matt M
(Post 3884341)
We pulled the motor to put in the clutch, replace the head, and swap back to the stock turbo.
Swapping the head is a pretty solid days work if you take your time and double check everything. We don't have DALs with the manual boost controller. We will get the boost leveled out for running this car on the street or at the track. For now, we are just pushing for higher numbers to see how everything responds. I put the stock intake and TB back on after a few pulls today. After a few more pulls, we dyno'd again with the boost controller bumped up a little and going WOT by 30mph. Max boost was 29psi and torque hit 428 ft lbs. Here's a couple pulls starting at different RPMs to show how the boost eventually fades to the same level regardless of how the pull starts. http://sites.commercecreators.com/fo...quemonster.bmp |
Originally Posted by Terminator2
(Post 3886066)
Oh, I thought you were using the MBC with just your big turbo setup. My bad. I dont think the stock maps like seeing that much pressure do they?
(Post 3886149)
They don't see it with the regulators in place.
I bet that turbo is making some NOISE now!
Originally Posted by Mazdaboi318
(Post 3886187)
i am still wondering how much a tubro swap upgrade kit will run!
(Post 3886257)
