LNF twin turbo anyone?
Some weird Swedish science lab: Division of Vehicular Systems, Lab
It says there max power was decreased due to turbo size (it probably spools on idle...), but thought it was a compact layout and maybe it inspires someone over here. (Or use some of those saab parts)
Yea lol I see all stock parts, open your eyes my son hahaha. Modified saab b - turbo system is essentially stock.. pretty cool but not necessary. If it were a big 4 cylinder maybe, like the 2.6 in my conquest.... meh. Irdc, it's bed time.
I don't understand how they ran a sequential setup and made less than 260@ the crank
Just read the quote it'll sink in. If you do not have the displacement twin turbo's is pointless. If you have a solid single bank exhaust it behooves you greatly to keep to just one tract. By having two you pull away from power to put it somewhere else. This is not legitimately feesible even with like a carbon fiber wiring system I don't think you'd get far.
This is a Twin Turbo set up from a Saab 1.9 diesel. I looked in to it at one point but the header flow was very restrictively low and BW engineer I talked to was concerned about handling the exhaust temps from a turbo gas motor.
And getting the plumbing right would be a nighmare.
--Christian
--Christian
I dont know if any of that is true its just what I thought what might happen.
On a exhaust bank note, everytime I see 4 exhaust tips for an inline 4 I get annoyed lol. Or any inline anything for that matter, or any single turbo car, etc. All I see is "wasted weight and money"
What if you made 2 completely separate exhaust manifolds? Two exhaust ports would feed each of the smaller turbos. This would eliminate the turbos fighting each other. Then on the charge side, there will be a y-pipe merging the charged air. Then, it's off to the inner cooler, then into the intake. Wouldn't the 2 smaller turbos almost eliminate turbo lag? On the exhaust side, the pipes would also be merged via y-pipe and then off to the muffler.
Hes doing a serial compound setup. so all 4 exhaust ports feed a smaller turbo (k04 size) then the exhaust gas feeds to a big turbo. As the small turbo spools the exhaust gas back pressure increases to spool the large turbo.
That saab setup looks like 4 ports of exhaust feed to both turbos equally which in a sense takes away from the spooling power. If you made one those turbos a big one. I guarantee it would barely spool if at all.
I am telling you this is a rocket pack on an ant, you'd be far better off putting a larger Whipple type supercharger, or the Turbo kits. At no point does the plumbing, tuning, extreme heat, and unholy mechainical failure risk due to so many added key essential parts make this effort worth pushing for more than to be a project demo.
There may be people doing it, and good on them, but practicality is very low, especially when this car can't launch hard it nearly defeats the idea. Remember we have 50% boost in 1st stock, why in the world do we need a twin setup to do what a ECU retune will do, or if your really trying to just smoke the tires go to a NHRA meet and get in the burnout contest and go for broke.
Is the guy that has been "working" on putting a big whipple on an lsj for a couple years now really talking about practicality? ??
No its not practicle neither is the whipple idea but both are out of the box and cool to see stuff being tried on a platform that gets sooo little r&d love from the aftermarket
patooyee
Oct 1, 2015 01:07 PM
