LNF Valve Gunk..
Old Jul 9, 2012 | 07:48 PM
C_A_D88's Avatar
Can't wait John I will hope to be one of the firsts with your solution on my car as unjust had this **** fixed and don't wanna have to do it again
Old Jul 9, 2012 | 07:51 PM
C_A_D88's Avatar
Originally Posted by raver0789
you might have had horrible build up already before your 5th injector. If you had a clean motor from the start the 5th injector probably would have helped keep the carbon at bay. But since you put it on a used engine with carbon already caked on, i have my serious doubts about it being able to take the old crusted stuff off.
I think these motors just eventually need new heads. there is nothing around it really.
Shouldn't need one at 60 000km as per my car did
Old Jul 9, 2012 | 07:55 PM
Boosted4's Avatar
I'd be game to purchase your solution too Mr. Powell. Get it done! lol
Old Jul 9, 2012 | 08:07 PM
Powell Race Parts's Avatar
keep an eye on the website or email gloria@powellraceshop.com she can put you on the list. The solution wont be cheap, it is effective and does require parts removal and installation.
Old Jul 9, 2012 | 08:12 PM
40rty's Avatar
the issues with coking on di motors is not new.
  • there is no one solution. I beleive that K&N and other filters with poor small particulate control are problematical
  • inlet valve temperature is key/200 degrees C inlet valve temp, is not a good number
  • pcv control is important
  • top tier hi octane fuel is important
  • low ash oil is important.
  • driver mod to deal with inlet valve temperature is important. low revs in 5th =ugh
  • Powell raceparts will offer a partial solution soon.
  • seafoam wont help in a di motor to any degree
  • using a wire brush in the inlet port is probably not a good idea. Walnut shell blast is better, wood particles burn when sucked in the cylinder, wire brush particles dont.
I am sad to hear meth doesnt help I had some hope for that, but the chemists say methanol wont do much for the coking buildup. Meth/water mix maybe?
stay tuned for a solution from us, its in the works and testing
Mr. Powell, I'm all ears!
Old Jul 9, 2012 | 08:13 PM
C_A_D88's Avatar
If it works as promised don't really care as long as its cheaper then a new head and intake valves again lol
Old Jul 9, 2012 | 08:15 PM
AaronJ's Avatar
^Why wouldn't it help if its fed in through the vacuum line?
Old Jul 9, 2012 | 09:01 PM
AARON-SS-TC's Avatar
interesting
Old Jul 9, 2012 | 09:10 PM
think about introducing material fluid or otherwise (that is not atomized or distrubuted by the throttle body) directly into the inlet port and ask what happens if this material or fluid is ingested into the cylinder and then compressed by the piston.
fluids dont compress easily
Old Jul 9, 2012 | 09:16 PM
padlock's Avatar
wouldnt that totally flaw the whole idea behind seafoam in the first place then?
Old Jul 9, 2012 | 09:39 PM
  #36
AaronJ's Avatar
Well the reason I asked is because I believe that the How To on this forum actually says to put it in through the vacuum line.
Old Jul 9, 2012 | 09:50 PM
  #37
Miko's Avatar
I have yet to hear a clear explanation about why the carbon build up problem occurs. Seems there is a new theory every few months. Theories like oil leaking from the valve guides, "dirty" PCV designs, failed PCV valves, and exhaust gases being present in the intake track. I would love to see a technical explanation for the issue based on sound theory backed up with scientific testing proving a product/technique works.
Old Jul 9, 2012 | 09:57 PM
  #38
emiller's Avatar
Carbon is a byproduct of burning gas. Combined with some oil blow by you get buildup.
The gas is injected directly into the cylinder so it never has a chance to wash off the carbon buildup from the back of the valves. In a port injection or carberated engine the gas is injected upstream of the valves where it can help wash them off.
And a link to read some more.
http://www.autoobserver.com/2011/06/...-adopters.html
Old Jul 9, 2012 | 10:10 PM
  #39
gone_in_10_sec's Avatar
John - I'm first in line - since I'm the OP who started all this..
In all seriousness, there has to be a solution to this problem.. not only me, but there are alot folks on here and on other forums who are willing to purchase a new head/valve train to have a working/performing engine period. It sux's to have the same problem with oil/gunk all over the place...
John - is it possible to produce a venturi tube or pcv type product?
Old Jul 9, 2012 | 10:11 PM
  #40
go to the thread i started about it on Mavens web site the gm sport compact one. then you can get some information. I have lots and lots of details and i summarized it in my post, and I refuse to share any of the details here. But to quote again, its an industry wide issue, its no one single root cause and there is no silver bullet fix. and it is a DI problem, emiller correctly explained why DI is an issue. I have not seen any new theories on this problem by the way. carbon builds up at specific inlet valve temperatures on a DI engine. etc. check my post earlier.
Old Jul 9, 2012 | 10:12 PM
  #41
padlock's Avatar
powell never ceases to impress me!
Old Jul 9, 2012 | 10:29 PM
  #42
if
you use top tier gasoline.
if
you use ( with not a lot of hope for it, but just because) techron gasoline additive.
if
you use my fix which is NOT a venturi tube you dont want to create any venturis anywhere lol
and
you should consider using low ash mobil 1 its the euro oil that Maven loves, i use it in my Saab wntrbtr2 turbo
and
u should not overfill your engine with oil at all
and
u should run in 4th rather than 5th on two lane roads, u will get better mileage anyway (key point here)
u should reconsider air filtration
then things will improve for you
providing the valves are clean to start with.
what i dont know is what the tunes are doing in this equation. I am not 100% that a tune that throws fuel at detonation wont add to the issues.
But I am confident that what I have in the works will help .
Old Jul 9, 2012 | 10:44 PM
  #43
scotch89's Avatar
so your saying to run in 4th gear on a two lane road like a highway (50-65mph)?
Old Jul 9, 2012 | 10:45 PM
  #44
yes. or short gear like i do to a 4.45. its all about inlet valve temperature.
Old Jul 9, 2012 | 10:50 PM
  #45
scotch89's Avatar
ill have to give this a try, ill be driving 65 all the way back to my home town= 420 miles. when i came up to my destanation i was getting average 36mpg at 65mph. so ill post when i go back, that will be august 8th
Old Jul 9, 2012 | 11:04 PM
  #46
email me i would be interested in what you find. i am thinking u run about 2100 in 5th@60 mph iirc ( havent cruised witha 3.86 for a long time ) and you want 3200 if you can i am thinking. also driving just 2 miles a day trips kill any engine , these maybe more. cheers. ps it says you got a saturn redline so that is a different car differnt motor and not this problem at all not DI.
Old Jul 9, 2012 | 11:15 PM
  #47
FF_ace's Avatar
Grey RTV is great, but once past 35-55+psi it's not going to hold boost for long - especially in my case..
no issues for me and ive ran 30+psi out of my pte5857 a few runs
Old Jul 9, 2012 | 11:19 PM
  #48
FF_ace's Avatar
im running a 75%meth to 25%distilled water mix for close to 20k miles with sometimes running pure meth still got build up like OP. its a 7gph nozzel im running
Old Jul 9, 2012 | 11:39 PM
  #49
Sir_Hiro's Avatar
Im prob gonna ask a stupid question but Im gonna do it anyway..does this problem only affect the LNFs? OR does it also affect the LSJs?
Old Jul 9, 2012 | 11:44 PM
  #50
CCrunner84's Avatar
LNF's, direct injection.
