LNF Valve Gunk..
Old Jul 16, 2012 | 08:12 PM
  #101
Frogstofall's Avatar
Originally Posted by gone_in_10_sec
rchiwawa take the free oil changes.. your passing up free oil changes no less with Mobil1 from the dealership? your crazy.. yea it far but it's free oil..
FYI - Dealership Service Receipts - have to show what oil has been used b/c just in case there is warranty claim - either from the dealership or from the consumer.. GM voids warranty claims b/c either the customer or dealership used the blend of oil.. it happens..
It just has a part number for the oil on my oil changes. I get free ones as part of the deal I worked out when I bought the car.
Old Jul 16, 2012 | 09:46 PM
  #102
rchiwawa's Avatar
I figure why waste the oil. I requested to see the outgoing oil filter when I ran it to 17% and it was by all concerned considered to be rather clean period, not just for the mileage (something like 8-9k). The car is driven 2 hours a day on commutes. 15 minutes in town roads at 35-45mph, 45 minutes freeway at 60-70 depending on how late i am running. I NLS 2-3 on the way out and run it to at least 80 pretty much every morning. The car never breaths dirt Save for the rare street sweeper or whatever gets kicked up in winter.
To illustrate how clean she breaths, it took over 60k miles before the dealer said the filter was looking like it was about done. The media was a dark grey something on the order of a #4 pencil on plain paper. I figure with the exception of raw miles and the fact that I will dd it in any conditions (Conti Extreme contact DWS may be useless as a performance tire in my book but in compacted snow and ice its close enough to a performance winter tire in said performance that I will deal with it's mush otherwise because it isn't as bad as a true performance ice and snow tire in the wet or dry... its close, though.) in and through the Seattle area hills, my car leads a pretty optimal life.
Beside that, I trust the engineers, mobil 1 oil, the oil coloration, and don't want the dealership to reconsider its policy of unlimited free lifetime oil changes regardless of required oil for all new sales. If enough ******** like me came in once every 5 weeks for their Mobil 1 Synth and I am sure the line would change. Maybe paranoia on my end about the dealer policy, but I'll take it as needed; Why abuse it with no discernible gain ?
Hopefully some of the solutions wont require huges sums of money. As I have found out that 200 degree c inlet valve temperatures are the point at which coking occurs ( assuming the presence of oil in the inlet tract) then your driving cycle and weather would sure be a contributor. Keeping excess oil out of the inlet is key, and thats my part of the solution. Stay tuned, sounds like you have done all the reasonable maintenence things anyone can do, and running the OLM normally into the teens is not a big deal. But for a DI engine, using low ash euro spec oil and changes at say 25% remaining would seem reasonable improvement.
I thought I read somewhere Mobil 1 Synthetic is no longer a low ash oil in grade 5w-30. I try to wait no longer than 50% but you know how it is. I am curious as to what a chunk of deposit breaking off of the valve would do.
I am holding out hope that the solution devised will be nigh imperceptible as a modification or not interfere with warranty. No matter what I've no doubt more than a few are watching.
Last edited by rchiwawa; Jul 16, 2012 at 10:00 PM. Reason: avoiding automerged double post
Old Jul 24, 2012 | 02:51 PM
  #103
gone_in_10_sec's Avatar
I see your point..
As for a chunk depositing on the piston, up to now I've seen only a few Ecotec engines with the heads removed in the shop, but only a few [5] with "caked-on" deposits both on the pistons and on the valves, and each one had new pistons/valves installed.. so I could see it dropping on the piston and "Melting" on the piston..
one of the GM Master Techs told me - it's been a known issue since Lotus/Yamaha designed the head in the early 2k's and even Bosch knows about it too..
Old Jul 24, 2012 | 04:00 PM
  #104
mmcgee123's Avatar
Thos happens due Not having raw fuel in the intake so the oil from the Pcv n whatever blow by cooks to the valve I'm a Mazda master tech n the same stuff happens to our 2.3 disi motors (speed6,3,cx7) there's no fix for it weber tryed numerous intake cleaners nothing helps
Old Jul 27, 2012 | 10:18 PM
  #105
Miko's Avatar
So if there are many different sources it seems that Wangspeed may have found one, over filling the crank case, he drained this out of his catch can apparently...
Originally Posted by Wangspeed
2 days on track. It slowed down considerably. It seems this engine really hates being topped off on oil. I didn't go over full, but it wants to blow it out when it's maxed out.
I was also thinking about where else can oil come from and then realized the turbo itself could be a source. My Stealth had oil in the charge pipes from leaking seals on the turbos, maybe a worn out turbo at high rpm/oil pressure might be one source. Maybe not an issue for low mileage or stock tune cars but anybody who runs their turbo hard or has an aftermarket turbo with a leaky bearing section could create this issue too. Problem is, how do you deal with oil from there? The only way would be some fancy charge pipe with a way to separate the oil from the air in high air flow volumes with low pressure drop. Yikes
Old Jul 28, 2012 | 08:45 PM
  #106
Powell Race Parts's Avatar
Miko you are a smart guy. This oil is NOT coming from the turbo. Its coming from the RC thru the pcv. Wangspeed is 75 % of the way there, the final solution will be ready this week. Warren is ahead of the curve on this deal.
Old Jul 29, 2012 | 10:27 PM
  #107
Miko's Avatar
75% of the bottle full apparently! LoL! I've been running the MPx catch can for a year now but it's bone dry. Hmmm, makes me wonder if I have a problem with it or have been lucky.
Old Jul 30, 2012 | 08:56 AM
  #108
I have no idea how its plumbed and what it is doing for you. Your motor may be perfect with a perfect drive cycle and 300 degree valve temps...
if its plumbed on the fresh air side, its not doing anything but getting in the way.
Old Jul 30, 2012 | 10:25 PM
  #109
Miko's Avatar
Nope, plumbed completely correct. Just to be safe I think I'm going to check my PCV valve.
Old Jul 31, 2012 | 11:58 PM
  #110
any news?
Old Aug 14, 2012 | 05:44 PM
  #111
AARON-SS-TC's Avatar
Zmax???
Old Aug 15, 2012 | 11:54 AM
  #112
After reading an independent review/paper on it, that stuff is pretty funky..
Old Aug 15, 2012 | 12:22 PM
  #113
Wangspeed's Avatar
Originally Posted by AARON-SS-TC
Zmax???
Is this a joke, or are you really that gullible? It's mineral oil.
Old Aug 15, 2012 | 12:28 PM
  #114
even the late Carroll Shelby - Stands behind this product!!
Old Aug 15, 2012 | 12:52 PM
  #115
blrt's Avatar
I am afraid the best solution might just be removing them and clean them after so many miles not a cheap simple solution?
Old Aug 15, 2012 | 01:11 PM
  #116
after reading a ton of posts on gm sport compac, the best solution for me IMO is the walnut shell blast..
yes - it costs a few coins - but after looking the "before" and "after" for what the BMW/Audi/MB guys have done already to cure this problem.. it's a no brainer..
doing the walnut blast and coupled with Powell's PVC product.. this could minimize the coking to a point, provided the walnut blast is done once a year and Powell's PVC product is clean & working properly..
Before "Walnut Blast" pic - I though this was the intake valve in the middle of port - that not bad oil coking? oh'boy was I wrong..
After "Walnut Blast" pic - look at it sparkle!!
Old Aug 15, 2012 | 01:45 PM
  #117
FRQ FLYR's Avatar
I'm not endorsing zmax but the mineral oil is merely a vehicle to carry the additive..
Old Aug 15, 2012 | 02:14 PM
  #118
good thread and good pictures of course I agree lol
Old Aug 15, 2012 | 02:29 PM
  #119
john - i read the post twice, i couldn't believe it's an easy process to perform after reading the manual..
here's the post: e90post.com
Old Aug 15, 2012 | 03:15 PM
  #120
its about a grand from harbor freight for a reasonable set up, u supply the vacuum. BMW kit for what they say is not redonkulous, gonna follow up on that thanks u da mang for sure. ya a canadian dealer for that outfit so we will see what I find.
Well update that went nowhere the canadian dealer sells shot blast dont know nothing about the machines and was offended I emailed them coz I am stupid to ask them for a machine all they sell is shot blast. live and learn. Back to harbor freight lol
Old Aug 15, 2012 | 08:53 PM
  #121
Miko's Avatar
I read the same BMW article a while ago too. The BMW tool itself is apparently on backorder everywhere because of demand. Walnut shell does seem like a no-brainer, especially for the factory dealerships. GM should be doing this rather than having their techs teardown the engine.
Old Aug 15, 2012 | 09:06 PM
  #122
I agree. I have put the the harbor freight blaster on our buy list. seems to make sense to me.
Old Aug 17, 2012 | 02:45 PM
  #123
this is a setup i'm looking to get to for my shop:
25 Lbs. Fine Grade Walnut Shell Blast Media @22.99 per bag
110 Lb. Pressurized Abrasive Blaster @$129.99
Abrasive Blast Cabinet @$119.99
Old Aug 17, 2012 | 06:42 PM
  #124
u need the vaccuum...lol . good stuff. in the cabinet, I suggest you use a soft aluminum silica or whatever they call it. in the floor model use the walnut shells for the heads and black shot for the hard stuff like rusted chevy rear axles off 1908 trucks lol
Old Aug 17, 2012 | 06:43 PM
  #125
ps u will need a dryer in the line just before the blaster to stop the moisture nonsense.... next week final pcv will be up and running around....
