LNF Valve Gunk..
Still a good deal... Lol
And what o rungs were you talking about that you oiled up and it worked like a charm again. I was thinking about the CRC spray... Don't think I'd feel comfortable doing the walnuts myself
walnut blastng is a walk in the park compared to rebuilding a damaged engine
Putting chemicals in the induction system has a risk. detonation on the fluid, damage to the pistons and rings, and in the case of a DI engine, neglible benefit or effect on the valve stem.
I would be more worried about a chunk falling into the cylinder and having its way. I really need to walnut blast my valves found out this weekend the previous owner did not (or at least the apperance of the intake runner made it look that way. Not super bad, just black build up on the walls.
Let's scratch that one idea from the table. I do have a friend with some of the equipment, just the air gun. Lets say we do this job together. This will take our whole weekend and sometimes we work weekends. I want to use the weekend he is most available to work on my girlfriends car's rust spot. If I had 2 days off, I would do it myself, but no availability. Also, neither of us ever did this before. Too much going on and I don't want to mess up the car.
Honestly, for what I'm doing...it would be a $600 for me to do it myself either way.
I had a helper. And by helper I mean a dad that watched over my shoulder. This is not rocket science. All info is in the intake removal and cleaning threads as well as this one.
Read the how to a million times. Do your due diligence. I was more than a novice. Its really freaking obvious when the ports are open or closed. You can see the open valves by the excess clean valve stem.
i would say based on what I do its sort of an all day job. It actually takes about an hour to pull the manifold and then half an hour to prep everything. The actual blasting and vaccuuming takes about 45 mins to an hour depending on the build up. 10-15 minutes a port. Then another hour to strip the pcv out of the manifold and clean it thoroughly, then remove the stuff that is protecting the engine.
we are at 3 hours or so. Now replace the manifold change the oil and filter ( filter while the mani is off as its easy, put the spark plugs back in etc... another good hour...
so add 30 minutes to clean the equipment, put the walnuts away, sweep and vacuum the shop and road test the vehicle .
I charge 600 including pcv, new mani gasket, oil and filter.... so you can prolly fit something else in to do but the day is about shot anyway after all that.
Is it best to just replace the pcv with a new one. Where they are only like $5 ? Or can they be taken out of the manifold and be cleaned up and put back in to re-use ?? I just bought a 50lbs bag of walnut blast and a media blasting gun. As well I have the intake mani gasket. So im getting ready to do this myself also very soon. I was really wondering if a new pcv is in order or if i can just clean and reuse the old one.
I am finding the gunk k must screw them up. Like u say cheap to buy. I would replace not clean. Use a 1/4 drive extension angled through the TB opening to tap out and a 3/8 extension as a drift to install new lithely lube the o ring to avoid cutting the o ring during install good luck with it. My 12 inch long extension pipes for the blast gun make it easier for m.
Thanks for the tip. But I always thought the pcv it self was in the intake manifold between the block and the manifold itself. I guess i am thinking it is in the wrong area ? For that matter. I'm not sure what the pcv looks like on an lnf. CED use to have them listed on their web site but I can't seem to find them anymore. I gues the dealer it is.
Okay , so I guess maybe I missed it because I was able toi find it on CED's website again. But I would love to know exactly where it is. Is it not in the deck of the intake manifold ?
LNF and it sits inside the blister in the manifold
LSJ is longer. PCV side by side
LSJ blister where PCV routes
the manifold flange side LSJ.LNF head orifice where the oil comes from, part of blow by gases, routed from base of the engine via the rocker cover
I looked did not find one; will take some tomorrow and if you email me it will be quicker cheers
Do what I did, take some thiner vacuum hose and tape it with hole lined up to blaster nossle, u can then get where ever u want in there. And for easy clean up of the wallnut blast in by the valves, do the same thing with shop vac, just use bigger hose
