Low vac at idle
Old Apr 25, 2010 | 10:04 PM
brycerice13's Avatar
Low vac at idle
Ok when my car is at idle it is normally at -20 vac but latley it has been at -25 vac ever since my ic piping came loose the last time and i reset my idle by disconncecting the battery for like 30mins, also the car seems just a little slower than normal any sugestions?
Old Apr 25, 2010 | 10:06 PM
peachpuff's Avatar
Double check your piping connections, otherwise do a boost leak test.
Old Apr 25, 2010 | 10:10 PM
mrsilent13's Avatar
-25 is really good vac...wish i could get at least -20...right now it can barely pull -15 which is actually low vac...but i think i found my problem...seems that one of my lines has a very small hole...so i will be replacing it tomorrow
Old Apr 26, 2010 | 03:38 AM
SSlobalt's Avatar
-25 is better than the -20 I get. It sounds like you got everything tight. What do you mean by "seems just a little slower?" Are we talking butt-dyno here? Those are unreliable.
Old Apr 26, 2010 | 02:42 PM
PrincessTurbo's Avatar
Mine sits at around -20 after its warm
Old Apr 26, 2010 | 03:18 PM
yeah mine used to always sit arround -20 when warm then i got my clutch changed and the guy fucked all kinds of stuff up im still tring to work out all the **** he messed up I was just woundering if this is normal or will it effect anything the idle is still smooth but when i let off the gas it goes -25 then somethimes slowly creeps up to -20
Old Apr 26, 2010 | 03:44 PM
I have never seen it go below -20 unless I had a leak in the CP ..
Old Apr 26, 2010 | 03:45 PM
wantedSS/TC's Avatar
wish the RPD showed vac!
Old Apr 26, 2010 | 03:50 PM
Stamina's Avatar
^x2
Old Apr 26, 2010 | 07:11 PM
Nighthawk243's Avatar
You think they would've put that in...
Old Apr 26, 2010 | 09:29 PM
DoMiStIc_RuSh_06's Avatar
Mine usually shows -60kpa
Old Apr 27, 2010 | 08:50 AM
Yeah, you THINK they would have.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Slick_Nick
Sep 28, 2015 09:15 PM
