Lowering Springs, what do you recommend.
Old Oct 25, 2010 | 04:40 PM
  #76
vahdyx's Avatar
Originally Posted by blk06ss/sc
i like how the pedders look, its pretty agressive with the front being lower then the back, handles like a charm also
Can you post some pictures for us, or maybe even a youtube video
Old Oct 25, 2010 | 04:51 PM
  #77
blk06ss/sc's Avatar
sure get off work in 10 min gimmie a couple
Old Oct 25, 2010 | 05:53 PM
  #78
whyyoumadson?'s Avatar
In your opinion
no fact is fact. on lnf struts the only things that come close are the pro kit and ssc's
ssc = the closest thing to stock spring rates with a similar drop of sportlines.
pro kit = crap drop(.5" in the rear) slightly better handling.....you still get coilbind
pedders = the best spring out for the lnf. highest rates, best handling with a decent drop. NO COIL BIND.
h&r/sportlines - sexy drop, poor handling, poor ride quality
remember this is on lnf struts not konis or anything.....regardless the lnf struts are better then they typical koni yellows.
Old Oct 25, 2010 | 05:56 PM
  #79
oh just to add aswell....stance coilover/hsd(made by the same company) are good....both need a higher rate in the back. kw variet 2's appear to be the best out as far as quality goes but ive yet to see someone with them on the car to give a legit review. bilstien internals ftw on varient 2s.
Old Oct 25, 2010 | 06:52 PM
  #80
Wangspeed's Avatar
God. Not this again. More suspension misinformation.
KW used to use Koni internals. Back in about 2003 or so, they had 2 sources for shock internals. Koni, and another lower end source. They've since bought their own German damper company, but they still make twin tube dampers. Not monotube, like Bilstein.
As for Koni vs LNF struts and shocks. I've run both now, and the Konis are hands down better. The car is more composed, and I'm able to rotate the car as easily as before. Like I said, I have the stock dampers ready to ship to someone in the industry to have them dynoed and compared to off the shelf Koni yellows. No more guessing. GM did a good job stock, but there's room for improvement.
Old Oct 25, 2010 | 07:06 PM
  #81
ecot3c inside's Avatar
im sorry but if I'm gonna pay $500 + for springs and struts I'm gonna get coilovers for a little more.
Old Oct 25, 2010 | 07:32 PM
  #82
Done debating with you. You wont hear anything other than what you say. And handling is not worse. The misinformed info on this site is retarded .....
Old Oct 25, 2010 | 07:58 PM
  #83
Wangspeed's Avatar
Super, and you can get coilovers with poor valving. There are so many coilovers that are poorly valved, it's astonishing.
Autocross to Win (DGs Autocross Secrets) - Buying Shocks
[FAQ] Shock Dynos - Honda-Tech
If the company you want to buy coilovers from won't provide you with shock dynos, run. Fast. I asked Pedders for a shock dyno of their coilovers, because I was interested in buying them, and they refused, and so I dumped them as a viable option.
Old Oct 25, 2010 | 08:00 PM
  #84
Wangspeed's Avatar
BTW - I've checked 2 sets of Pedders now, and they coil bind in the front under heavy load. If you don't believe me, pull one, and look at where the powder coating scraped off.
Old Oct 26, 2010 | 12:23 AM
  #85
you can debate all you want.....ive had them on my car. again i understand you have koni yellows...good stuff and with springs im sure it handles better. im saying on Fe5 struts they dont. they are a far softer spring. rides super bouncy and every bump you hit feels like the car bottoms out. im sure wangspeed will agree on this aswell.
Old Oct 26, 2010 | 01:10 AM
  #86
I had stock struts for two years and they held up great on bumps until they blew. Then it rode like hell.
Old Oct 26, 2010 | 07:49 AM
  #87
lnf or lnj oem struts?
something im realizing about the springs...since the lnf cars have come out only 1 new spring has been realeased. pedders. they were tested on these cars where all the other springs were tested on lsj cars. so sure i can see what your saying. they were an upgrade on the lsj fe3 struts. most of the companies figured with interchangable parts why put out a totally new product? but the struts on the lnfs, springs, sway bar, etc etc are different. lnf cars handle way better from the factory if you ask me. like i said on my car they rode horribly. i was scared to even whip it around turns because there was a lot of body roll....my buddy that bought brand new fe5 struts and bought my old springs has the same complaint. the only thing we both like is how they make the car look. to me by far the nicest drop and thats why i have the stances pretty close almost the same but my rears a slightly higher.
Old Oct 26, 2010 | 09:51 AM
  #88
I See what your saying. They are similar cars but yet different all together. My car actually decreased body roll. Which there in itself I noticed an improvement
Old Oct 26, 2010 | 10:06 AM
  #89
vahdyx's Avatar
What happened
Old Oct 26, 2010 | 11:07 AM
  #90
see and on lsj struts im completely sure thats what would happen where as on lnf struts the springs are just too soft for them. like i said the fact of interchangable parts makes a huge deal in the aftermartket....most companies said screw it. the struts/springs mount the same why produce different springs? people will still buy them because your average moron buys lowering springs to get the car lower not handle better.
even my stance coilovers could use a stiffer spring in the rear.
Old Oct 26, 2010 | 12:07 PM
  #91
blk06ss/sc's Avatar
gotta make a photobucket first i dont have good connection
Old Oct 27, 2010 | 04:37 PM
  #92
blk06ss/sc's Avatar
sry took so long here ya go
Old Oct 27, 2010 | 07:54 PM
  #93
vahdyx's Avatar
sexy, I'm buying a set eventually
Old Feb 23, 2011 | 11:29 AM
  #94
flaniganrm's Avatar
Any one try the Megan racing springs?
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
