LSJ to LNF clutch mounting differences?
Old Jul 20, 2009 | 07:44 PM
sheldon729's Avatar
Can someone who has installed a new clutch into their LNF tell me if there is a difference i dont seem to think there should be besides the stock clutch hp/tq ratings. all bolt patterns should be identical. same tranny and release bearing used. so im woundering if the centerforce DFX01010249 clutch will work from crate engine depot
Old Jul 20, 2009 | 10:24 PM
Gettinausernamesucks's Avatar
The flywheel was made thinner on the LNF to accomodate a thicker clutch and clutch cover. Not entirely sure if an LSJ clutch will work on an LNF but I don't think so.
Probably be best to drop CED an email and ask them
I also recall the that the LNF may have more bolts holding the flywheel to the crankshaft.
Anybody else??
Nope I just checked and they both use 8 MTG bolts to the flywheel. So thats the same.
Last edited by Gettinausernamesucks; Jul 20, 2009 at 10:24 PM. Reason: Automerged Doublepost
Old Jul 20, 2009 | 10:47 PM
Matt M's Avatar
In our experiences, if you install an LSJ clutch in an LNF, the clutch will engage a little higher on the pedal. Likewise, if you put an LNF clutch in an LSJ, the pedal will engage low.
Old Jul 20, 2009 | 11:08 PM
sheldon729's Avatar
but what is your running an lsj clutch with lsj flywheel? as per thats what the centerforce kit comes with
Old Jul 21, 2009 | 12:10 AM
Matt M's Avatar
Yes, sorry, I was referring to the complete LSJ assembly including flywheel.
Old Jul 21, 2009 | 01:08 AM
sheldon729's Avatar
ill prolly just wait till centerforce come out with the DFX 6puck kit for the LNF becuase i get cost on it woohoo
Spanky's Monkey
Mar 7, 2016 06:06 PM
Tupp
Sep 29, 2015 11:07 PM
ashalle2
Sep 16, 2015 10:36 PM
The Rookie24
Sep 14, 2015 07:03 PM
brett.higgins3
Sep 14, 2015 01:48 PM
