MAF codes, lack of boost, help!
Old Jan 20, 2013 | 07:12 PM
  #51
SSlobalt's Avatar
Originally Posted by sreid
installed new purge solenoid and vent valve. valve required me to buy a new harness because they changed the valve and connector. erased codes, see how it goes, so much snow out cant get car out.
I haven't seen snow in 20 years. What does it look like, again?
Old Jan 21, 2013 | 06:39 PM
  #52
sreid's Avatar
We just had 3 feet of it week ago. i popped engine light on high rpm in 2nd gear today. p0103. erased it, poped p0101 in pending next vehicle drive cycle. erased it. still getting maf codes, anything else? or is it from the intake. i dont think it is cause it never did this before.
Old Jan 25, 2013 | 03:45 PM
  #53
sreid's Avatar
poped p2178 again and p0101 another time. makes me think boost leak i guess ill check again
Old Jan 25, 2013 | 08:09 PM
  #54
SSlobalt's Avatar
Pull the bumper cover and get out the soapy water, this time. If you still don't get it, just take it in. It's been way too long.
Old Feb 4, 2013 | 03:50 PM
  #55
sreid's Avatar
still never got around to hawling off bumper cover, but have been popping p0101 p0103 p0451 p2178 at different times but i just erase them...
Old Feb 5, 2013 | 05:26 PM
  #56
sreid's Avatar
Got my hands on live data. L t fuel trim -16%. St is everywhere too what should be normal at operating temp
Old Feb 5, 2013 | 07:36 PM
  #57
ATLsilverSS's Avatar
As close to 0 as possible
Old Feb 5, 2013 | 08:35 PM
  #58
SSlobalt's Avatar
Wow. Longterm that high is crazy, but you've been driving like this for a while. You have to find the leak. Post a pic of your hose and TMAP sensor on your coldside pipe.
Old Feb 6, 2013 | 11:55 AM
  #59
sreid's Avatar
What list of data would you like so I can lift it from the car same time.
Old Feb 9, 2013 | 01:41 PM
  #60
sreid's Avatar
url changed posted below
Old Feb 9, 2013 | 02:13 PM
  #61
sreid's Avatar
heres the live data i have recorded, one is at idle, one id town driving sensibly. harsh winter roads makes it a little bumpy may have to pause to see the driving parms from the video.
Driving: IMG 1689 - YouTube
Idle: IMG 1688 - YouTube
Old Feb 16, 2013 | 04:32 PM
  #62
sreid's Avatar
Old Feb 16, 2013 | 05:16 PM
  #63
SSlobalt's Avatar
Just take it in. It has been too long for you to be driving around with it like that.
Old Feb 17, 2013 | 04:04 PM
  #64
sreid's Avatar
plan on it this week, just hard to make time in my schedule for myself lately. just was hoping something might catch an eye of a known issue.
Old Feb 24, 2013 | 08:02 PM
  #65
sreid's Avatar
boost leak tested, found lower map sensor o-ring to be cause. swapped o-ring with another one i had. reset codes, cleared fuel trims, seems to be ok ill give it a bit of driving and report back
Old Mar 5, 2013 | 04:15 PM
  #66
sreid's Avatar
check engine light is back. had pending p0103, cleared code, car stalled and acted sluggish. then p2199.
going to boost leak test again make sure nothing happened ( roads are nasty here ) .
Old Mar 5, 2013 | 06:00 PM
  #67
Chevy_tuner's Avatar
This is scary.....
Wouldn't that intake on a stock tune hurt the fuel trims just as stated? Do you have a downpipe?
Tune............
Old Mar 5, 2013 | 07:35 PM
  #68
sreid's Avatar
erased p2199 and popped up again after a short run for coffee. going to monitor iat1 iat2 and see what i come up with. got a new maf coming hopefully shortly to just get that out of the way.
Old Mar 5, 2013 | 08:59 PM
  #69
SSlobalt's Avatar
I think I still get a cookie for this one.
Old Mar 6, 2013 | 12:52 PM
  #70
sreid's Avatar
Agreed. But I am still having troubles. Lol.
Old Mar 12, 2013 | 04:10 PM
  #71
sreid's Avatar
looks to be a leaky fuel injector, will get booked in for replacement on warrenty and go from there
Old Apr 20, 2013 | 09:11 AM
  #72
sreid's Avatar
ok, still having some troubles, was out of the country for a little while an left car parked. checked, now have p2178 as my only code at this moment, also get low coolant light on cold start every time. coolant is at proper level. still getting lack of power, very noticable when cold, did find lower map sensor leaking and repaired with new o-ring. never got nothing done with fuel injectors because they never looked at it, will rebook an they will check for hpfp oil leak an the fuel injectors next visit.
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Extremespeed
Sep 29, 2015 04:34 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
