maf sensor cel
Old Dec 5, 2008 | 12:51 AM
cobalt85691's Avatar
maf sensor cel
after about 7k miles on my 3" intake a cel came on and i reset my ecu i disconected the battery i cleared the code with an obd reader and i put stock airbox back on and the cel keeps coming up. any ideas on how to get it to clear
Old Dec 5, 2008 | 01:13 AM
08BlackSS/TC's Avatar
did you actually test the MAF sensor to see if its functioning properly? obviously that light keeps coming on for a reason and its not your intake since it happened after 7k miles
Old Dec 5, 2008 | 01:22 AM
how do i check the maf sensor?
Old Dec 5, 2008 | 01:36 AM
cobaltssoverbooster's Avatar
check for ground, 5 volt refrence voltage, and youll need a scope for the signal back to the ecm
add or correct iff im wrong
Old Dec 5, 2008 | 01:42 AM
how do i do this all step by step...what do i need to get?
Old Dec 5, 2008 | 01:56 AM
vulcanturbo's Avatar
See if its dirty or something is in it....
Old Dec 5, 2008 | 02:09 AM
i would recommend just putting it back to stock and taking it into the dealer oscilloscopes arent cheap and you will probably want one to check the signal. i would say at around 90$ for a maf sensor best to take it in for free replacement 8)
08blackss/tc ------ well i dont think this one made the cai no cel club
well actually if you have hpt record the maf signal and check it against a known goood signal.
Last edited by cobaltssoverbooster; Dec 5, 2008 at 02:09 AM. Reason: Automerged Doublepost
Old Dec 5, 2008 | 02:10 AM
chris88z24's Avatar
What the **** code is it?
Old Dec 5, 2008 | 09:06 AM
the car is still under warranty, just take it to the dealer and have them check it out
Old Dec 5, 2008 | 11:48 AM
IsItFast?'s Avatar
What is the actual code? It may be its being triggered by something else... Or maybe your filter was over oiled and it got the MAF dirty.
Old Dec 5, 2008 | 12:30 PM
choko's Avatar
prolly p0101.
im having same issues
I killed 4 mafs
me nor dealer can find issue
switched to stock intake and still wiping out mafs, a problem lies somewhere. if i figure it out ill update on here,.
i have no power with maf performance range/circuit problem.
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
