manual datalogging today.....long post...
Old Feb 12, 2011 | 03:13 PM
G5 Man's Avatar
Went out this AM to the other vehicle, which is an hour away from home, so I thought this would be the time to check all of the parameters out from the AeroForce gauge. Average speeds were between 65-80 mph in OD. No laptop, just pen and paper, oh well, I did get readings. Some of the results that I am posting, I don't fully understand, and maybe the forum can guide me along or direct me to where I can obtain more info and a better understanding. Remember I have an Auto 08 HHR SS, so there may be some numbers that would differ from you manual guys, I would assume. No dead stop WOT's or Passing gear WOT's as the turbo is not operating correctly due to the BPV malfunctioning, which should be corrected in a week or so when I receive the Forge unit. So here we go.......
HAHN BSR (PPC) Tune w/K&N drop in filter
IDLE.............................................. ........................Highway Driving
Long Trim B1 & B2...............16.4............................1 7.1 16.4 14.8 15.6 in that order
Short Tim B1 & B2...............-1.5 2.3 3.1..............between 0.7 & 1.5
Eng Load..............................0............... .................depending on throttle position 30 63 78 99
Rail Press.............................22.............. ................CL
Rail Press di................................................ ...........667 through 828
Run Time.............................3.9 4.0......................9.1
Barometer...........................14.3.......... ..................14.3
LAMBDA...............................1.00 .99...................as low as .91 high as 1.02
B1S1 CMD EQ.......................0.99..................... .......0.99
A/F Ratio..............................14.6 14.7...................14.6 14.7
02 Current...........................-127 -128...................back & forth constantly -127 to +127
ABS Throttle Pos....................0.......................... ......no fuel 0 with fuel 14-18 high as 22 depending on throttke position.
Throttle Volts.........................0................... .............forgot that reading
MAF Frequency......................1862............... ............3169 4732 5486 depending on Throttle position
Trans Temp F........................138 degrees................141 degrees
IAT 2 F..................................50............. .................high as 46 low as 38
Knock Retard.........................0.................. ..............0 1 time on the way out did see 1.2
PW Bank 1 & 2.......................0.0....................... ......0.0
Misfires..................................0....... .........................0
Fuel Trim Cell.........................0.................... ............0
02 B1S1 mv...........................0.................... ............0
02 B2S2 mv...........................545 + or - 5................25 up to 925...same for B2S2
A/F CMD................................14.69.......... ...............14.69
Oil Temp................................179........... .................197
TCC Mode..............................0............... ..................L
TCC DC%..............................0................ .................40 to 86 depending on throttle position
Shift Time ms.........................0...................... ...........155
Trans In RPM.........................750................... ...........1987
Trans Out RPM.......................0....................... ...........2840
TRQ To Trans.........................0................... ...............2457
Slip Speed RPM......................0........................ ...........0
TC SLP SPD RPM....................0.......................... .........0
BAROM PSI............................7.7................ ................7.7 plus or minus
RAIL PRESS............................7.7.............. .................7.6
Analog 1 & 2...........................gauge just shut down and then came on again..has happened more than once
CAT TEMP B1S1.....................777...................... .........1108
MAP KPA................................33
THROTTLE PCT.......................16...................... ...........varies
IGNITION ADV.......................3.5 4.5 2.0.................varies, seems to be all over the place, low as -2 high as 42.5
Well there you have it, I took the readings in the order that they appeared on the gauge, I left boost readings out as I produced very little boost during this log event. Feel free to comment or not no comment just thought these findings were interesting, now to understand some of what they mean........still thinking about the custom tune in the future............................................ ...................................Tom
Old Feb 12, 2011 | 04:08 PM
Iam Broke's Avatar
That one should be close to zero or slightly negative, the intake is causing the ECU to add gobs of fuel, you are running lean so the system is correcting for it. It's adding 16% fuel.
Put the stock air filter in and see if it gets closer to zero after 10-20 miles.
The rest look fine for cruise.
Old Feb 12, 2011 | 05:35 PM
G5 Man's Avatar
yes in that order and I failed to mention that I cleared all codes when I got on the highway, so the LTFT was reset to "0". I will put the stock filter back in and see what happens, thanks for the tip....appreciated............
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Tupp
Sep 30, 2015 08:18 PM
Tupp
Sep 29, 2015 11:07 PM
