MAP Sensor issues and injector seals?
Old 01-03-2012, 07:03 PM
AndrewSS/TC's Avatar
Ok, I have had some issues blowing MAP sensors, most will say its Caused by oil blow by, however when i pulled the sensor to replace it there was a strong smell of gas on the sensor. no oil residue though. So my question is could a bad injector seal spit enough fuel to blow a MAP sensor, the car runs normal with no issues.
It has me very confused.
Old 01-03-2012, 10:07 PM
Bump.
Old 01-03-2012, 10:29 PM
FasterIsBetter's Avatar
Originally Posted by AndrewSS/TC
Bump.
Injectors don't feed fuel anywhere near the map sensors. They only feed into the head and not the intake mani. Your map sensor will smell slightly like fuel kind of like how really old used motor oil smells. You may not actually see the oil on it but it gets inside of it when your car is under boost pressure.
Old 01-03-2012, 10:31 PM
Chevycobaltss3's Avatar
Andrew what's next to the map on the mani? The purge is. Weren't you having issues with that r was it bad.
Old 01-04-2012, 09:17 AM
I have all sensor issues. Evap is hit and miss, 02 also. I'm pretty fed up.
Old 01-04-2012, 10:03 AM
Lol my 02 took a **** on me two days ago. Lol
Old 01-04-2012, 01:14 PM
I am seriously thinking of going back to 100% stock. I just want the ******* thing to run right.
Old 01-04-2012, 01:33 PM
Oh hell. That's not gonna help you. Just get a catch can and a purge valve solenoid. Remember you gotta pay to play unfortunately. I have reminded myself that multiple times, lol!
Old 01-04-2012, 10:30 PM
I've been debating on buying a catch can for like 3 days. Haha I can't make up my mind.
Old 01-04-2012, 10:32 PM
rogersj's Avatar
catch can is worth it man
Old 01-05-2012, 01:33 PM
i replaced the Evap purge solenoid, and purge valve. STILL trying to get this thing through emissions. Still debating on a catch can....................
Old 01-05-2012, 02:33 PM
What do you mean through emissions? Are you getting a check engine light? That would be the only way you would fail. That and catless exhaust. If so, let us know exactly what the cel was for.
Old 01-05-2012, 03:05 PM
no CEL, readiness moniters are not complete 3 of 4 are ready, evap is not.
Old 01-05-2012, 03:07 PM
If evap isn't tuning then run 20 15-30 min cycles without loading a tune to the car. Also check to see if coolant temps get to 172+ if not it won't run a few tests
Old 01-09-2012, 08:59 PM
Bump, car is throwing P2237 so front o2 is prolly bad, o2 and evap still aren't complete.
Old 06-02-2012, 03:58 PM
A.J.'s Avatar
Will a blown map sensor cause a p0299 code to pop up. Also dose it cause your car to run in limp mode because mines out and ill have boost for a bit then loose it again.
Old 06-04-2012, 11:15 AM
My car never went into limp mode, just part throttle boost spiked like crazy.
Old 06-04-2012, 01:58 PM
G Speed's Avatar
don't waste your money
Old 06-06-2012, 10:52 PM
Car was totaled in feb. lol
DarrenGC
12-24-2021 01:55 PM
Sl0wbaltSS
11-21-2018 11:11 PM
anotherslowlnf
09-29-2015 03:52 PM
yellow dragon
09-28-2015 09:49 PM
jmelton327
09-26-2015 10:04 PM
Quick Reply: MAP Sensor issues and injector seals?
