May have solved 100% E85 on LNF puzzle
Old Mar 9, 2011 | 10:11 AM
  #151
ebristol's Avatar
Originally Posted by jarhead
The E85 in Utah is E70 year round as are a lot of other states. people seem to make good power on it that are running it?
Originally Posted by RoadconeTuning
FWIW our local stations in Upstate, SC are all at full 85% ethanol now...
There are lot of people in the industry who wish they would run an E70 blend all year in all locations.
Old Mar 9, 2011 | 11:59 AM
  #152
drewbroo's Avatar
I just wish stations carried an E50 blend, or an E pump with differend blend options
Old Mar 9, 2011 | 12:16 PM
  #153
InfraRedline's Avatar
We have E30 blender pumps here, but its not quite as high of an E content as most would like.
Old Mar 9, 2011 | 03:00 PM
  #154
silverbullet08's Avatar
really looking forward to this. I have a couple LNFs here that want to run this underlay as well. I wish there was a way to do a switchable tune with the option of adjusting both tunes via hptuners.
Old Mar 9, 2011 | 05:58 PM
  #155
turbohornet88's Avatar
i cant wait for this. i want to run corn now.
Old Mar 9, 2011 | 08:20 PM
  #156
Iam Broke's Avatar
Vince - Anything new today on the development?
Old Mar 9, 2011 | 08:27 PM
  #157
VinceTrifecta's Avatar
Not today, I spent the last two days getting caught up on the work that piled up on Monday from going out and spending most of the day tinkering with this stuff. LOL.
However, I'm going out later to investigate the fuel rail pressure stuff to see what is going on there, and whether it looks like it's going to be a big problem, or not.
I still need to integrate the findings into the layer file for people like you and others.
Old Mar 9, 2011 | 08:38 PM
  #158
PrincessTurbo's Avatar
Originally Posted by VinceTrifecta
Somewhat to my surprise, nobody has approached us directly about obtaining what we've uncovered in the Bosch ECMs. And it's not for a lack of trying to get this information, either.
IE HPT
I wouldn't expect much they pretty much fooked us all..
Old Mar 9, 2011 | 08:50 PM
  #159
ssblackstealth's Avatar
corn gas ftw....
y cant tyler, tx carry e85!!!!
arrgggggggg
Old Mar 9, 2011 | 09:29 PM
  #160
Iam Broke's Avatar
I hate when work gets in the way. lol.
Gotta make the donuts. Thanks for the update.
Old Mar 9, 2011 | 09:37 PM
  #161
JustACobalt's Avatar
damn it absolutely no e85 stations within 50 miles of me. god my car would love e85
Old Mar 9, 2011 | 10:20 PM
  #162
army_greywolf's Avatar
On the thoughts that the hard line supplying low pressure to the HPFP could indeed be the problem, I'm going to modify it (read drill it out a little bit through the brazing). I undid it, and cannot fit a .065 bit through it...that's a problem. The hard line is 1/8" but the hard line is BRAZED to a flared end, which is a obvious problem. Now im not saying that it's the problem but I took that line off and got less than a liter after an entire minute of bypassing the relay. I also think most of you have forgotten the basics of mechanical injection systems. EVERY system is designed so that it's maximum fueling is available from idle to redline. What it means is the positive displacement of the pump is designed to outpace the injection window. I did simple math on that and even if the efficiency is less than 50% there is good chance you cannot inject more fuel at maximum rail pressure (although I wonder about 2800 psi, the aforementioned may be null considering that) than the pump displaces.
The pump is not gear driven for those who don't know, it's actuated by a three lobed cam at the end of the intake cam, directly on a tool steel piston assembly, internally it's preloaded on a spring. The fuel pressure regulator is the EXACT same regulator used on diesel trucks. The pump itself SHOULD be capable of flowing right up to it's pressure relief preset at maximum injection window at ANY rpm.
Alternate reasons for problems could even be evident in the pressure regulator itself, it's mechanic aspects of control. I know cp3 guys modify the pressure regulator to flow more at it's maximum pressure window but leave the taper alone so it can properly regulate lower pressures and handle low speeds better.
As always decipher my ramblings, some of this is more than worth looking into.
Old Mar 9, 2011 | 10:48 PM
  #163
Iam Broke's Avatar
I have a spare HP fuel line I didn't use when I replaced the fuel rail and injectors. A 9/64" (.140x) bit fit tightly into the braised ends. Perhaps I'll remove the original tomorrow and see if this spare would be an upgrade.
Thanks for sharing AGW.
Edit: Misread your post and was looking at the HP side, Iz tired.
Old Mar 9, 2011 | 11:50 PM
  #164
Omnigear's Avatar
any1 asked bill about the mech pumps?
Old Mar 10, 2011 | 12:34 PM
  #165
Update from last night's testing. Basically confirmed what Matt said they saw. To wit:
What are we looking at here? You can see the actual fuel rail pressure (FRP), it's the red line in the middle box. The green line is supposed to be desired fuel rail pressure, but it looks like Scan XL has a scaling issue. The regulator command wasn't showing up here (but I did further scanning with a Tech2 and capture regulator command later).
Where the vertical white line is, is where I kicked on my tune to high boost mode in 2nd gear. Up until this point the FRP was right where it was supposed to be, but then you can see the load (boost) jumps, and the FRP takes a dive to 1650psi (it's supposed to stay at 2100psi).
I shift gears, and the pressure rises again - actually overshoots the 2100psi target (likely as the ECM is unwinding the regulator trim), stabilizes at 2100psi again, then falls down to 1020psi (!) once the boost ramps in, in 3rd gear. It climbs up to about 1400psi and stays there until I let off the gas. Note also the injector pulsewidth is almost 14ms with no injector window misfire (!). Thanks advanced injection timing! ;-)
I did some further testing with the Tech2 and watched the regulator command. It seemed to max out at 165*. Even as the actual FRP fell to half of what the desired FRP was, the command seemed to max out at 165* or so. This tells me:
1. The regulator is at the mechanical limit (doubtful because I saw spikes as high as 168-169*)
2. The "closed loop regulator trim" system is at the limit of its adjustment (most likely)
3. A hardcoded software limit for regulator command has been reached
To date, everything Bosch did in the programming for this ECM seems to be centered around close tolerances to factory specifications (injection timing, FRP, etc). That likely means there is more available on the regulator command but it just doesn't go there because the LNF was never designed to need this much fuel mass.
However, this seems to be the end of the line. If we can't get more out of the regulator (reliably) then we can say we've reached the limits of the fueling system mechanically and programatically of the LNF here. We'll have to start looking to increasing the pump capacity, mechanically.
It doesn't mean necessary that we're out of luck (yet), though. With our increased injection window, we can tolerate a lower FRP (and longer IPW) and perhaps slowly ramp it up as RPM climbs.
Old Mar 10, 2011 | 12:54 PM
  #166
Iam Broke's Avatar
Any way to see what the inlet pressure side of the pump looks like to know if it's starving out?
  #167
That was my theory also, especially when we saw this problem resolve to some degree on the V6 Camaro when we commanded a higher low pressure pump pressure, but Matt said they checked that and saw a constant 60psi on the inlet on the LNF.
Old Mar 10, 2011 | 01:32 PM
  #168
Iam Broke's Avatar
OK, now that you posted that I remember Matt asking me to check mine last year but I never got a fitting or transducer to do it. Thanks.
I'm going to pull the supply line off tomorrow to see if it's as small an opening as AGW's is.
Old Mar 10, 2011 | 02:05 PM
  #169
I expect varience if you look close on mine my fitting isn't a perfect match to the line...
Old Mar 10, 2011 | 02:08 PM
  #170
SSlobalt's Avatar
Is this the supply line to the HPFP that AGW is talking about? Is this the supply line from the tank pump? I'm trying to learn more about what you guys are talking about. Thanks.
Old Mar 10, 2011 | 02:29 PM
  #171
Garret's Avatar
this thread delivers
Old Mar 10, 2011 | 02:35 PM
  #172
BYT*SS*TURBO's Avatar
Old Mar 10, 2011 | 02:37 PM
  #173
slowbalt84's Avatar
^this
Old Mar 10, 2011 | 02:42 PM
  #174
Originally Posted by BYT*SS*TURBO
Nice!
More like @#$*(&@#$*!@#$&!@#$&!()*)*#$%(*#$@ Fuel
Old Mar 10, 2011 | 02:43 PM
  #175
Garret's Avatar
lol^
