meth?
Old Jun 29, 2010 | 04:53 PM
  #51
smthomas556's Avatar
Originally Posted by Terminator2
FF_ace's car needs that meth in a bad way. His car knocks on less than stock timing and 0.87 PE lambda (I have tried it as rich as 0.85 PE lambda with no change in KR observed). I had him add some 100 unleaded just to confirm the knock was real because it is unbelievable. I have never seen an LNF knock on less than stock timing and 91 octane and his fuel trims are almost perfect. Oh well the meth should make for some big gains. I just wish I could be there in person to tune it. Email tunes are always a little harder.
We will have it installed on Saturday morning. We have been working a little at a time.
Old Jun 29, 2010 | 10:45 PM
  #52
devilsown's Avatar
Originally Posted by HHRSSouth
Could've sworn I read some where that DevilsOwn said to go with water injection if your not going to tune it and meth injection if you are?
I recommend running a 50/50 mix at most for all untunned applications. Also if not going to tune for the mix you also need to usually run a smaler nozzle than what you able to run once its tunned in. You need to tune for 100% methanol you can limp around a tune by running a small nozzle but your not going to get the cooling you need to show gains.
Old Jun 29, 2010 | 10:59 PM
  #53
iboost's Avatar
I have a kit coming in soon from AEM. Where is everyone mounting the meth holding containers? I got the 1 gallon can.
Old Jun 30, 2010 | 08:55 AM
  #54
hiltu's Avatar
Originally Posted by BYT*SS*TURBO
We just installed meth on Oscar's car and ran the same tune (timing, afr and boost) but adjusted the trims to get the afr/trims back in line obviously. The car made 343/424 with a 60% meth 40% water solution. 17* peak timing, .88lambda and 24psi. I know there's more in in too, haven't even leaned on it hard yet!
Sounds promising... Maybe i can join the 400WTQ club?
Old Jun 30, 2010 | 09:33 AM
  #55
Gunney_07's Avatar
i wonder how the ko4+ is going to respond to the meth?
Old Jun 30, 2010 | 09:36 AM
  #56
hiltu's Avatar
I been on meth for over 3/4 of a year, i got it before the bandwagon got started
Old Jun 30, 2010 | 02:23 PM
  #57
cardelino18's Avatar
question!!!
ok so lets say i get a meth kit... using the windshield whipper fluid...
would i need to have 2 tunes??? 1 for meth use and the ontherone for normal "daily driving" tune?
also where could i get meth... what brand is the best to get?
Old Jun 30, 2010 | 02:29 PM
  #58
ecot3c inside's Avatar
Originally Posted by cardelino18
question!!!
Old Jun 30, 2010 | 02:34 PM
  #59
cmiller8006's Avatar
question!!!
You dont need two tunes because the meth is only activated when you either hit a certain boost level, rpm, maf signal and so on. So it will always be on tap for when you hit the gas, and while your just cruising it is off.
Old Jun 30, 2010 | 02:51 PM
  #60
iboost's Avatar
where are you guys mounting your tanks?
Old Jun 30, 2010 | 03:42 PM
  #61
I just ordered a kit. Mine is a trunk mount kit. http://www.coolingmist.com/detailmain.aspx?pid=VC2FS
Old Jul 1, 2010 | 10:40 AM
  #62
Nakaiya21's Avatar
I am using the snow performance stage 2 kit with the safeinjection. Here are a couple of things I have found....
1.) Good idea to actually get this installed by someone who knows what they are doing. The directions I received are for a volkswagon
2.) Get the safeinjection
3.) You will probably have to by the upgraded solenoid... it doesn't really point this out on the website - but you find it is warranted when you read the directions
4.) Resevoir placement - still have to figure this one out. There really isn't a good place to put one under the hood... right now we are looking at usplastics.com to see about getting an alternative tank
5.) Don't scrimp on fluid... we found a lot of veriability in windshield washer fluid. If you are paying the money to put this kit in - make sure that you can afford the fluid for it as well. Snow performance sells boost juice which is a 49/51% mix. Most of your cost for fluid will be in the s/h fee since it is a haz transport item.
As for your maps... Vince (trifecta) can tune for meth. Once I finish up he is going to upgrade both my conservative and aggressive tunes. I am also installing the KO4+, upgraded intercooler, and K&N intake so it should be interesting to see how everything works out. Unfortunately I won't have a good handle on what the meth alone attributes since I am changing so much at once...
Oh, once last thing - not sure if this is true or not - but I have heard that for rear mounted kits you may have to install a second pump...
Old Jul 1, 2010 | 10:43 AM
  #63
iboost's Avatar
I heard that someone mounted there tank under the hood...I'm jus curious where?
Old Jul 1, 2010 | 11:19 AM
  #64
RYRO14's Avatar
Trunk
Old Jul 1, 2010 | 11:25 AM
  #65
FF_ace's Avatar
i have mine in the trunk as well will post pics up soon. sat we will be putting the finishing touches on the kit and tuning it later that day
Old Jul 1, 2010 | 12:41 PM
  #66
iboost's Avatar
So that extra pump post up there is non sense?
FF ace - lookin forward to the pics
Old Jul 1, 2010 | 12:42 PM
  #67
FF_ace's Avatar
i will have them up on sat
Old Jul 1, 2010 | 01:11 PM
  #68
Yes I laughed at that too.
Old Jul 1, 2010 | 02:55 PM
  #69
devilsown's Avatar
hehe,
with out kits we supply a check valve so you don't need to order a solenoid. I don't think its right to send a kit out to someone knowing they will need something else to make it work right in there car. Evey car must have a solenoid or a check valve.
tanks usually have to be mounted in the trunk. I know most people that buy our kits tend to go for our new 2.5 gallon tank that has the sump and baffles built in. its the best tank on the market.
Old Jul 1, 2010 | 03:35 PM
  #70
hiltu's Avatar
ill take a pic. Mines underhood.
1qt. tank, big enough that i only fill up every few weeks. You can see my low level sensor. The 220 PSI pump is under my headlight, and the check valve leads from the pump to the 5GPH nozzle into my coldside charge pipe.
Old Jul 1, 2010 | 06:33 PM
  #71
Wangspeed's Avatar
5gph is too much for the stock turbo and air flow.
Old Jul 1, 2010 | 09:08 PM
  #72
hiltu's Avatar
Im pushing 26ish PSI on the K04+ turbo...
Old Jul 1, 2010 | 10:52 PM
  #73
Nakaiya21's Avatar
^^^ thanks for the information... it really comes in handy over here... we will be on the lookout for the smaller reservoir. People don't necessarily realize how little meth they need...
Old Jul 2, 2010 | 07:37 AM
  #74
hiltu's Avatar
you keep referring to "we", what exactly is "we"???? and as far as your comment about people don't realize how little meth they need, through devils own calculator, it said to use a 4GPH nozzle, and yes thats rated at 150PSI, not 220PSI like my pump is. After running that for 3/4 of a year, i bumped in up 1GPH and have no negative side affects. Just waiting to hook up with BYT in person to get the pig tuned.
Old Jul 2, 2010 | 09:00 AM
  #75
Wangspeed's Avatar
Do you have a flow meter? The larger the nozzle the worse the mid boost area behaves. You're probably on a progressive controller and there's only so much it can do to spray smaller amounts. It may or may not be a nice even spray. It's easier to get predictability out of a smaller nozzle. I ran with a flow meter and it was hooked up to a fail safe. When I started off with a 7gph it didn't behave well at mid boost, like moderate acceleration for a few seconds. I went down to a 4gph nozzle, everything was much better. That was with a legacy gt with an sti manifold and modified turbo pushing about 330whp.
I had to step up to a 6gph when I went to a bigger turbo, Garret 3076 based. I never did like the 12-18psi characteristics of the meth system with that nozzle though. It's amazing what you find out with an actual flow meter hooked up to your meth system.
I wouldn't run any smaller than what Hiltu is running. It's too easy to starve the pump in turns if it gets any smaller.
Hiltu, I dunno how you get away with such an itty bitty reservoir :-) Since I had at one point planned on tracking my previous car, with WI, I had 2 one gallon reservoirs hooked up together.
If I was doing a front mount pump, I'd just feed off the windshield wiper reservoir. Taller is better, and just fill it with 50/50. It's easy to get that mix. Just put in cheap no frills -20F wiper fluid that doesn't soap when you shake (35% methanol, there should be a label about %35 VOC) and add 3 bottles of yellow HEET.
