Methanol Install Suggestions
Old Apr 22, 2011 | 11:41 AM
D-mac's Avatar
Waiting on a AIS Stage 1 with the 3 gallon black tank kit to show up
How are you guys installing these
Where are you running the Fluid and electrical?
How far from the TB are you mounting your nozzles?
Any good other tips?
Old Apr 22, 2011 | 11:53 AM
tomj77's Avatar
in the trunk, run the lines under the car, run the elecrical inside the car anyway u want. put the nossel just after the intercooler in the lower charge pipe
Old Apr 22, 2011 | 11:55 AM
Gremlin85's Avatar
^This.
It's best here. Allows enough time to mix and cool properly in the intake charge when installed there.
I'm excited to get mine!
Old Apr 22, 2011 | 12:44 PM
Iam Broke's Avatar
After reading the info on the AIS site, I'm thinking of installing the nozzle in my ZZP lower CP where the MAF block off plate is a few inches before the TB. Haven't decided yet. I ordered the Comp Underhood kit but it looks like the tank will have to go in the trunk anyway. Looks like the tank is too big to fit in the space between the fender and my intake. We'll see when it arrives Wed. Still debating using the WWF tank too.
Old Apr 22, 2011 | 03:34 PM
D-mac's Avatar
If i have to run the Wiring inside the car what would be the issue with running the Fluid Hosing with it inside the car?
Anyone done it this way?
Old Apr 22, 2011 | 03:38 PM
BooSSted's Avatar
It's just safer to run it outside the car. If there is ever a leak or anything you won't make a mess of the inside of the car. It's got to go outside the car at some point in time, so it might as well be at the back.
I've got the same kit, just waiting to install it when I put on my CP's and intercooler. If it ever warms up that is....
Old Apr 22, 2011 | 03:41 PM
Gremlin85's Avatar
Could always use the washer fluid tank as your supply. But then again, I would rather have a seperate tank for meth anyway.
I saw a couple install pics of the fluid hose that was run inside the car. Either works, but my paranoid ass would rather have it on the outside god forbid a crack or burst happens somehwere along the line.
Another thing I was thinking of is that if you run it under the car, you don't have to tear apart your interior. Wiring goes to the battery in the trunk where the tank and pump will be anyway (assuming thats where you're installing everything), ground to metal, and then just one hole to send the fluid hose through.
Up to you.
Old Apr 22, 2011 | 05:02 PM
tomj77's Avatar
if ur running it on the outside, the fluid line, make sure u get 5/8 fuel line and run the high pressure line through that for protection
Old Apr 22, 2011 | 05:16 PM
slowstang's Avatar
I have an AIS stage 2 meth setup coming in the mail. If I get around to installing it before you i'll take some pics and share how I did it.
Old Apr 22, 2011 | 05:44 PM
D-mac's Avatar
Great
Install pics and suggestions are always welcome from everyone
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
TedSS
26
Oct 10, 2015 04:30 PM
justinchinn
Oct 2, 2015 12:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
